Pilot RC Sbach 100cc
Rich too
Posted by Ultymate on 16/10/2019 20:16:48:
Purely a matter of taste, but I always whenever possible use a cable between the throttle servo and the carb and rely on the throttle spring to close the throttle. This greatly reduces the amount of vibration being fed directly into the servo
Yeah, I've heard others do that, but the method I use is tried and tested - MG servos are a must. I always leave the springs in place. I've never had an issue.
Posted by Adrian Smith 1 on 16/10/2019 22:48:48:
Nice tidy work there, Rich. Do you know what size/type of prop you will use? Was the servo matching unit easy to do the job?
Thanks Adrian. I think it's a bit of OCD!! I've gotten more concerned with vibrating and chafing wires, and fuel tubing as I've gotten older! I believe I've got a 28 x 10 for it, I can't remember the brand - I'll use decent CF ones when I stop breaking them! wink Yes, the X24 unit is a doddle to use once you get the hang of it. I am very pleased with it. I also may want to use twin receivers so we'll see how easy that is to set up.
