trebor Posted December 20, 2017 Share Posted December 20, 2017 Due to lots of servos Ive got another 5v/5a Ubec to use rather than the Ecs Rx power supply. Also trying to cut down on channels could I just use the signal wire from the Esc and the live and ground from the separate Ubec onto the throttle channel of the Rx ? Quote Link to comment Share on other sites More sharing options...
McG 6969 Posted December 20, 2017 Share Posted December 20, 2017 Hi Trebor, I would think your ESC needs some ground (-ve) as well. So, if you want to free up a channel, you should connect the grounds of both ESC and UBEC together in the throttle channel. But then if I were you, I would wait for some 'Electro Musketeer' to jump in & correct me. Cheers Chris Quote Link to comment Share on other sites More sharing options...
trebor Posted December 20, 2017 Author Share Posted December 20, 2017 I know on some quad flight controllers you can run Escs just on the signal wires but Im not sure about being able to tune the Escs without the ground. I will keep my fingers crossed for some help. Quote Link to comment Share on other sites More sharing options...
Eagle 899 Posted December 20, 2017 Share Posted December 20, 2017 Yes, that's the method I use. Here's a youtube example: **LINK** Shep Quote Link to comment Share on other sites More sharing options...
trebor Posted December 20, 2017 Author Share Posted December 20, 2017 Can you still change the Esc programming ok ? Quote Link to comment Share on other sites More sharing options...
Former Member Posted December 20, 2017 Share Posted December 20, 2017 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Eagle 899 Posted December 20, 2017 Share Posted December 20, 2017 Posted by trebor on 20/12/2017 17:06:21: Can you still change the Esc programming ok ? Don't see why not, though I haven't had to because I programmed the esc before wiring in the UBEC. Quote Link to comment Share on other sites More sharing options...
