John B 2 Posted March 25, 2018 Share Posted March 25, 2018 Building my first rc plane - a West Wings Slingsby Skylark 1.8mtr wing span 4 x 9 gram servo, 3 channel motorless glider. After hours of searching I'm unable to get any further than a 2 cell lipo with an esc linked to receiver is what is required. How do I make sense of all the numbers on each product in relation to each other? (I'm new & not sure if I have chosen the right topic to place my question). Quote Link to comment Share on other sites More sharing options...
John Tee Posted March 25, 2018 Share Posted March 25, 2018 Not a glider fan. If you have no motor you don't really need an esc just use an Rx pack to power the receiver and save a bit of space. I'll leave anything else to the experts. John Quote Link to comment Share on other sites More sharing options...
Andy Blackburn Posted March 25, 2018 Share Posted March 25, 2018 I assume you mean BEC (battery elimination circuit) rather than ESC (electronic speed controller)? Even if that's the case, I'm still a bit confused about the question; I assume that you want to know what you need (electronics-wise) to get a working model? I think it really hinges on what you're going to power the receiver & servos with, which is really about what you have available to recharge the receiver battery. The options are: 4-cell NiMh battery of (maybe) 1000-2000 mAh for a model that size (depends what will fit in the nose), and a fast NiMh charger. This has the advantage that it won't catch fire in a crash. A 2-cell LiPo of similar capacity and a separate BEC to get the voltage back down to 5 volts, and a separate LiPo charger. Some receivers and servos will run happily off a 2-cell LiPo, you'll still need a suitable LiPo charger though. This is probably the lightest set-up, but if you hit them hard enough LiPos will catch fire, so it's a question of balancing risk. Edited By Andy Blackburn on 25/03/2018 18:07:15 Quote Link to comment Share on other sites More sharing options...
Piers Bowlan Posted March 25, 2018 Share Posted March 25, 2018 Personally I would use one of these. Just keep it simple, just plug it into your receiver, no need for a UBEC or voltage regulator as with a LiPo battery. Panasonic Eneloop batteries tend to keep their charge too. Welcome to the forum, by the way. Edited By Piers Bowlan on 25/03/2018 18:33:00 Quote Link to comment Share on other sites More sharing options...
Cuban8 Posted March 25, 2018 Share Posted March 25, 2018 Welcome John. The model you're building is designed either for thermal soaring from a flat (ish) field from a bungee launch or from a slopeside in moderate to light conditions. First thing is............. do you have somewhere suitable to fly? Secondly, what radio gear do you have or intend buying, Have you ever flown R/C models before, are you starting right from scratch.? Once we get a picture of your status, it'll be easier to post some suggestions. Never fear...........we all had to start somewhere Quote Link to comment Share on other sites More sharing options...
Old Geezer Posted March 26, 2018 Share Posted March 26, 2018 Best advice I could give is: find your local club(s) - easy enough using the BMFA club finder - visit their flying field(s) to get the feel of things - once you've broken the ice there will be lots of flyers keen to show you the "what, how & why" of their planes. Do this the sooner the better as you're going to need somewhere to fly anyway, and someone to teach/mentor you. Oh, and you're going to need insurance too - you get that automatically if you join the BMFA. Come on in - the water's lovely. Quote Link to comment Share on other sites More sharing options...
John B 2 Posted April 1, 2018 Author Share Posted April 1, 2018 Thank you all, I think I have my solution to what electronics I need, this post for me was all about the build, this has been a great help, the Eneloop 4.8v nimh to go with my 5v 8xr Taranis receiver (volt range 4+v) removing the need for an ESC & BEC looks good to me. I'm no doubt an unusual rc newby as I'm simultaneously learning to fly with a foamy glider at a field with a club / insurance etc whilst building a balsa vintage. I'll also be off to appropriate slopes when I'm ready. I did mean to put ESC but now understand why BEC would of been more appropriate. Quote Link to comment Share on other sites More sharing options...
