martyn sharp Posted August 22, 2008 Share Posted August 22, 2008 I Have just orderd one of these and it says that I need 2 x GWS IPS motor/gearbox (3.5:1 gear ratio) and wonderd if anyone can help with the brushless equilvent.if anyone has got the kit or flown one I would be intrested in hearing about it Many thanks as useall Martyn Quote Link to comment Share on other sites More sharing options...
Former Member Posted August 23, 2008 Share Posted August 23, 2008 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Brian Parker Posted August 24, 2008 Share Posted August 24, 2008 The Blue Arrow 1230 420Kv is a direct replacement for the IPS motor and uses the existing gearbox. Its an inrunner so a little expensive. Micron Radio Control stock them. Quote Link to comment Share on other sites More sharing options...
260 Flyer Posted August 24, 2008 Share Posted August 24, 2008 MartynTwo of these would be great in the DH 89.I used one in my Brigagdier which was designed for the IPS .No modifications were required, it screwed directly to the IPS mount and used a 6X4.Two 7X4's will give you more power than you need on a 2S1P LiPo. Quote Link to comment Share on other sites More sharing options...
Brian Parker Posted August 24, 2008 Share Posted August 24, 2008 Sorry…Mistyped on previous posting should be 4200Kv not 420kv. Quote Link to comment Share on other sites More sharing options...
martyn sharp Posted August 26, 2008 Author Share Posted August 26, 2008 Thanks guys you given me some Iders need to look at the type of fitting be for i decide but at lease it wount cost me a arm and a leg Martyn Quote Link to comment Share on other sites More sharing options...
martyn sharp Posted August 31, 2008 Author Share Posted August 31, 2008 I received the model on saturday ( at Bournemouth's air show) but didn't get a chance to have a look till today this is a builders model but very nice it was well packed and arrived undamaged so well done SMC the cut parts seemed to be well cut and the wood looks like a good grade.there are 3 plan sheets one for the fuselage one for the wings and one for the engine installation,which is useful when i start to in stall and possably change the engines up so far i,m impressed .also dose anyone know what happen to the DH89 that use to fly round mount Snowdon.Martyn Quote Link to comment Share on other sites More sharing options...
martyn sharp Posted September 5, 2008 Author Share Posted September 5, 2008 any Ideas Timbo ? and did you have a good holiday ?Martyn Quote Link to comment Share on other sites More sharing options...
martyn sharp Posted September 29, 2008 Author Share Posted September 29, 2008 On the advise of a fellow member I did a more through check of the kit and found that most of the problems he had encounterd were also inhearant in My kit. On the lazer cut parts one of the ribs is not inclueded,even if it was printed it would not be there, also the 1/16th blasa strip was twisted and cut badley and had to be replaced (now done ) the fellow member had by all acounts been through talk to the seller (not the same place as i got mine from) and then talk to the manafactuor the useal backwards and forwards . These are only small points but they can add up but other wise i hope this will turn in to a good model .time to stop my moaning and get on with some workall the best Martyn Quote Link to comment Share on other sites More sharing options...
michael harper 2 Posted April 14, 2017 Share Posted April 14, 2017 Just found this thread. I have a Dumas kit as well, waiting to be started. There's a few threads on RC Groups website. Try these: https://www.rcgroups.com/forums/showthread.php?1009606-Dumas-Dragon-Rapide https://www.rcgroups.com/forums/showthread.php?559571-The-DeHavilland-Rapide-for-Twin-IPS https://www.rcgroups.com/forums/showthread.php?1650419-Another-Tritle-Dragon-Rapide-Build-and-Maiden-Flight https://www.rcgroups.com/forums/showthread.php?1564907-Funbuild-5-42-DeHavilland-DH-89-Dragon-Rapide-kit-by-Dumas&highlight=dragon%20rapid Must try and start on mine. Quote Link to comment Share on other sites More sharing options...
Rapide Posted February 28, 2023 Share Posted February 28, 2023 I have this kit and at the motor mounting stage but have been trying to work out best way to mount them. George at 4-Max sold me a bundle that he recommends for this kit and it included 2 x PPOM-2314-2400 Brushless Motors which have a mounting cross to be fixed to the rear of the motor. Offering them to the plan, they seem to fit inside the outline of the fairing but I have to construct a firewall to bolt the cross to. Has anyone mastered this and can suggest the best way to do it whilst saving weight? Quote Link to comment Share on other sites More sharing options...
Allan Bennett Posted February 28, 2023 Share Posted February 28, 2023 Can the motor shaft be moved so that it protrudes at the other end? This can be done with some similar outrunners, allowing you to then mount it behind the front wall of the engine bay. Quote Link to comment Share on other sites More sharing options...
