Brian Dorricott 1 Posted May 6, 2018 Share Posted May 6, 2018 hi all, I picked up an unused ASP 75 sometime back but am unsure what to put it in ? . Until Saturday I had a Arising Star with SC 46 which I just got running properly when it totally loss control and went down in heavy woodland , not found yet but taking 17 year old grandson better eyes better legs to look today. So something nice and docile to fly and get used to IC as passed A but still improving hopefully . Arising Star was just right as learned on a leccy Epioneer and am happy with that learning a bit more on it. The similar Seagull Boomerang etc would be a bit overpowered on a ASP 75 or would it ? Anything else take the 75 and be a easy fly ? If a little overpowered throttle always available . Quote Link to comment Share on other sites More sharing options...
Don Fry Posted May 6, 2018 Share Posted May 6, 2018 Plan, kit, or ARTF. Quote Link to comment Share on other sites More sharing options...
Brian Dorricott 1 Posted May 6, 2018 Author Share Posted May 6, 2018 Prefer ARTF to kit bit short on room in workshop/loft and thinking of transport anything much bigger than 66in one piece wingspan might have trouble fitting in a small to medium Skoda. Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted May 6, 2018 Share Posted May 6, 2018 The trouble with using half throttle on an overmotored model Brian, is twofold Its an heavier lump on the front that the model is not designed for And the motor never quite gets up to temperature or useful torque And your throttle thumb, never quite gets the hang of useful throttling. Bite the bullet and fit it in a 75 model, you can easily get a 6 foot wing in your car Quote Link to comment Share on other sites More sharing options...
Steve Hargreaves - Moderator Posted May 7, 2018 Share Posted May 7, 2018 The Boomerag would be a rocketship on a 75 Brian.....flown at full power it would be pretty exciting; true you have a throttle but I think you might have a bit of trouble slowing it down for landing with that big prop on the fron moving a lot of air. There is also ground clearance to consider.....a 75 would use a 14" prop....I doubt it would clear the ground in standard form....you'd need much bigger wheels or a longer nose leg... There used to be a huge trainer type model for up to 90 4 strokes. It was around 80" span I think...like a very large Telemaster.....can't remember the name now.....that would be ideal. Another option might be the Wot4 XL.....on a 75 with reduced throws that would be a pussy cat.... Quote Link to comment Share on other sites More sharing options...
Steve Hargreaves - Moderator Posted May 7, 2018 Share Posted May 7, 2018 Found it...the Super Frontier from World Models.....80.5" span.....listed for a 46 but I think that would be a bit small personally..75 would be nice in this 7lb model.... Again though check the ground clearance for the prop...if it's designed for a 46 it will be expecting an engine with a 11 or 12" prop... Quote Link to comment Share on other sites More sharing options...
Don Fry Posted May 7, 2018 Share Posted May 7, 2018 How about a Black Horse Chipmunk, or Bird Dog. If you can fly a trainer either of these will suit. But just bear in mind either of the above are a step up in price from your trainer. Now a second hand small two stroke is cheap enough. Don't fall into a trap of spending a load of money, because you have the engine, and then breaking the airframe, because you're are not quite ready, losing heart ( or wallet depth), and walking away from the hobby. Common reason for people leaving the hobby. Edited By Don Fry on 07/05/2018 12:37:14 Quote Link to comment Share on other sites More sharing options...
Brian Dorricott 1 Posted May 7, 2018 Author Share Posted May 7, 2018 Thanks for replies might look out for something smaller in the 45/52 range then the choice of airframes opens out again . The SC 46 that I lost came up cheap on the BMFA website so I'll keep looking at ads and save the ASP 75 for annoying my neighbour when she has a barbecue it's great for blowing the smoke back over her garden and drowning out her yapping dog ! Cheers Quote Link to comment Share on other sites More sharing options...
Don Fry Posted May 7, 2018 Share Posted May 7, 2018 Although a very fine engine, I am impressed by ASP engines, good carburettor, but in its future planned roll, if you take the pressure nipple out of the muffler, you get a really annoying little blatt off it. Quote Link to comment Share on other sites More sharing options...
