Neil67 Posted August 13, 2018 Share Posted August 13, 2018 Trying to set up a wot 4 with dual ailerons on a spectrum DX6 radio with 6 channel receiver. How do I set up ailerons so they work independently, if I use a y lead they obviously both go in the same way and there appears to be no way to reverse one servo. I am sure this can't be difficult but still new to dual ailerons. I have power in bind socket, rudder, throttle and elevator as normal and a battery checker in gear. Left with aux 1 and one aileron socket. Quote Link to comment Share on other sites More sharing options...
Dave Hopkin Posted August 13, 2018 Share Posted August 13, 2018 By the position of the servos - have the servos facing in opposite directions Left hand wing with the output arm facing the tip and the right hand wing one also facing the tip Use the Y lead and they will work as an opposed pair Quote Link to comment Share on other sites More sharing options...
PatMc Posted August 13, 2018 Share Posted August 13, 2018 You can use a Y lead. The servos need to operate the same way as the connection to the horn will be from opposite sides of the servos. Quote Link to comment Share on other sites More sharing options...
Steven S Posted August 13, 2018 Share Posted August 13, 2018 You should try your Y lead to realy see what happens. I use a Dx6 and all my planes have the ailerons on Y leads and work properly. Quote Link to comment Share on other sites More sharing options...
Nigel R Posted August 13, 2018 Share Posted August 13, 2018 Aileron channel is left servo, aux 1 is right servo (I think), set wing mix to dual aileron. Install servos as a mirror image, everything will be right as rain then. Either servos upright, with both horns going towards the tip, at neutral. Or laying flat, with both output horns outwards, and with the horns both at front, or both at back. Check on how your servo reversing is set up - I cannot recall if you have to reverse both channels at the same time, or if you just reverse the aileron channel. I've set up a few on the DX6 and don't recall any specific oddities about it. Quote Link to comment Share on other sites More sharing options...
Neil67 Posted August 13, 2018 Author Share Posted August 13, 2018 Thanks guys, clearly a senior moment on my part, too obvious for words, feeling a bit thick right now! Duh! Quote Link to comment Share on other sites More sharing options...
Cuban8 Posted August 13, 2018 Share Posted August 13, 2018 Perhaps I'm missing something here, but on my six channel models I simply select the appropriate wing type during setup and that's that. RH aileron to aileron port and LH aileron to Aux 1. Quote Link to comment Share on other sites More sharing options...
Fatscoleymo Posted August 13, 2018 Share Posted August 13, 2018 Never managed to fly anything with a single aileron.... tends to be a bit wobbly.... Did you mean dual servos.... Fats Quote Link to comment Share on other sites More sharing options...
MattyB Posted August 13, 2018 Share Posted August 13, 2018 Never ceases to amaze me how many people stick doggedly with y-leads despite almost every Tx now being able to handle dual aileron servos. Obviously it’s still important to set up the linkage geometry correctly, but the advantages of being able to tweak the centres, diff and throws independently (not to mention flapperons, snap flap and spoilerons where appropriate) are huge. Spend the time to learn how to set them up, it’s well worth doing and removes additional physical failure points too (I’ve seen many nasty, cheap y-leads and extensions cause crashes over the years). Edited By MattyB on 13/08/2018 19:59:20 Quote Link to comment Share on other sites More sharing options...
Nigel R Posted August 14, 2018 Share Posted August 14, 2018 I have a couple of AR400s that couldn't do dual servo wing without a Y lead. Or maybe you have a warbird with gear and flaps to drive somehow - that won't work on a DX6 with dual aileron servos any other way. Quote Link to comment Share on other sites More sharing options...
