Tim Flyer Posted March 11, 2019 Share Posted March 11, 2019 Hi Chris that is because i knew it would be tight with spinner backplate to mount length specified on this model at 120mm . The back plate to rear carb length on a laser 70 is 125 mm but the exhaust is slightly within that but the engine rh thrust offset angle brings it in a bit . I’m doing it this way as I have the materials to do it and I prefer the cleaner look with a bit less of a hole in the side of the cowl . On my other laser installations in Wots I also have Standard exhaust elbow protruding from the cowl but this time I’m having a change . Maybe your spinner to backplate is slightly longer than mine as I was planning to do this from the beginning rather than shifting engines to suit the firewall. Anyway the main reason im doing it this way is just my personal preference 😉 Quote Link to comment Share on other sites More sharing options...
Chris Walby Posted March 11, 2019 Author Share Posted March 11, 2019 Tim, Thanks for the rational...just thought I had missed something As they say there are many ways to skin a cat and in this hobby there are normally plenty of different ways of doing things. I'll be watching to see how yours comes out both in build and performance. Quote Link to comment Share on other sites More sharing options...
