Stearman65 Posted January 21, 2019 Share Posted January 21, 2019 I have this kit in my stash as next in line. The only information I can get from Krick is the motor they use is "MAX Aero A356". I have Googled this & can only see it listed on the Krick site, but it is out of stock. Does anyone recognise the model, if I could get this motor it may save having to modify the mounting with a different manufacturer. **LINK** Quote Link to comment Share on other sites More sharing options...
leccyflyer Posted January 21, 2019 Share Posted January 21, 2019 My Krick Klemm flew very nicely with the power train that was in it when I bought it at a swapmeet from a clubmate. That setup was a Hi_Motor 2814 6 turn, pulling 36 amps on an 11x5" prop on 3s1p 2200mah Lipo for 420W in. The model's just like a big glider really with a massive wing area for the weight, 14oz/sq ft wing loading! Quote Link to comment Share on other sites More sharing options...
Stearman65 Posted January 21, 2019 Author Share Posted January 21, 2019 Posted by leccyflyer on 21/01/2019 19:36:32: My Krick Klemm flew very nicely with the power train that was in it when I bought it at a swapmeet from a clubmate. That setup was a Hi_Motor 2814 6 turn, pulling 36 amps on an 11x5" prop on 3s1p 2200mah Lipo for 420W in. The model's just like a big glider really with a massive wing area for the weight, 14oz/sq ft wing loading! Hi Leccyflyer I assume you are talking about the AXI 2814 16? That's what came up when I Googled the number, if it is the AXI spec says models up to 1.6KG? Krick give a weight of 2KG & I build heavy. Do you know who supplies the Hi_Motor? Quote Link to comment Share on other sites More sharing options...
leccyflyer Posted January 21, 2019 Share Posted January 21, 2019 Not an AXI 2814, it's a Hi-Models motor 2814 like this one **LINK** but it's a 6 turn, rather than 8 turn. Quote Link to comment Share on other sites More sharing options...
Stearman65 Posted January 21, 2019 Author Share Posted January 21, 2019 Posted by leccyflyer on 21/01/2019 22:10:54: Not an AXI 2814, it's a Hi-Models motor 2814 like this one **LINK** but it's a 6 turn, rather than 8 turn. That's in the USA, are they sold here? Quote Link to comment Share on other sites More sharing options...
Geoff S Posted January 21, 2019 Share Posted January 21, 2019 I would think any motor capable of a max current of around (say) 30 amps and a kv of 1000 rpm/volt would do the job. The hole spacing of those engine mounts is fairly standardised, too, but it would be wise to check. Have a look on HK, BRC, or 4Max. This one might do the job. Geoff Quote Link to comment Share on other sites More sharing options...
Stearman65 Posted January 21, 2019 Author Share Posted January 21, 2019 Thanks Geoff, I'll take a look in the morning. Regs Eric. Quote Link to comment Share on other sites More sharing options...
leccyflyer Posted January 21, 2019 Share Posted January 21, 2019 I suspect the motor would have been from Giantcod or possibly Hobbyking. As Geoff says other equivalent motors are available, The model only needs modest power. Mine weighed 3lb 13oz, (1.7kg) with a couple of oz of lead in the nose and that's more than 100w/lb with a very light wing loading. Quote Link to comment Share on other sites More sharing options...
Piers Bowlan Posted January 22, 2019 Share Posted January 22, 2019 Maybe this one if only modest power is required. Or this one if a bit more grunt is required? Edited By Piers Bowlan on 22/01/2019 06:49:21 Quote Link to comment Share on other sites More sharing options...
Stearman65 Posted January 22, 2019 Author Share Posted January 22, 2019 Had a good look around at the suggestions & back to the email Krick sent. The spec' of the motor they suggest is Technical Specifications Type MAX Aero 3548-06 Voltage range 11.1 - 18.5 V Speed/Volt 800 rpm Total length 66 mm Housing dimensions 35x48 mm Shaft diameter 5 mm Free-standing motor shaft 16.5 mm Mounting holes M3 thread Mounting holes Bore spacing 25 + 19 mm Connection 3x mm gold contact plug Matching propeller 12x6 inch / 13x8 inch with a 3S lipo. It is much more expensive than the current suggestions, & being a little green on electrical matters, (by 11 years) I don't want to have buy the wrong thing. So I've gone with the Krick selection which is now in stock & ordered one, (needed to do it before March 29th anyway). I'd rather have more power than needed than not enough. Thanks to everyone who made suggestions. Quote Link to comment Share on other sites More sharing options...
Piers Bowlan Posted January 22, 2019 Share Posted January 22, 2019 That changes everything! This is closer to the spec than what I suggested, but I am glad you found the motor you were looking for. Edited By Piers Bowlan on 22/01/2019 07:38:13 Quote Link to comment Share on other sites More sharing options...
