Gary Murphy 1 Posted January 29, 2019 Share Posted January 29, 2019 Been away from the hobby for a fair while and not used my spectrum gear for longer than that! I have some small park fly receivers with no satalite socket BUT I have several larger 6 and 8 channel receivers with a satalite socket BUT I can not find the satalites. Can I run these without the satalite? I know the range will be less BUT its for surface use only Quote Link to comment Share on other sites More sharing options...
Former Member Posted January 29, 2019 Share Posted January 29, 2019 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Paul Marsh Posted January 29, 2019 Share Posted January 29, 2019 The Ar8000 won't work without a Sat, neither will the 7010 - they have been designed to work with them, the only exceptions is where on the larger receivers, such as the 9ch where they can take 4 sats, but are supplied with 3, with the option of adding a 4th. The 6210 will work, as the older 6200, but not really recommended... Quote Link to comment Share on other sites More sharing options...
Don Fry Posted January 29, 2019 Share Posted January 29, 2019 Fit a battery, bind, and see. For surface work at safe speeds it won't cause harm. Quote Link to comment Share on other sites More sharing options...
Gary Murphy 1 Posted January 29, 2019 Author Share Posted January 29, 2019 It will be at safe speeds,it will go in a Scania semi truck,1/14th scale! I have a 6110 and 6200,the hard cased 6200 was my preferred but has the satalite port, I will do as suggested and bind and see what happens. Quote Link to comment Share on other sites More sharing options...
