LED Bulbs
Gary Murphy 1
I need to fit led bulbs in a project and never used them before.
A diagram shows a resistor fitted at the bulb. I will need to bend really tight to the bulb.
Can I fit the resistor away from the bulb? ideally if I could fit it 12 inches away that would be great. If that is not going to work how close will it need to be?
The resistor can be fitted anywhere in the LED leads and is not polarity conscious, but do you know the value and Wattage of the resistor you need?
To work this out you would need to know the LED voltage and current. If you post the supply voltage and the LED ratings on here, I am sure some kind person will calculate the resistor value and Wattage rating for you.
Barry
But to answer your original question...
It does not matter where in the circuit the resistor is as long as it is in series with the led. All the current must flow through the led and the resistor. (As opposed to in parallel with it. If they are in parallel then current can flow through either the led or the resistor.)
What is important is that the led is fitted the right way round with respect to +ve and -ve.
Plummet
Edited By Plummet on 18/02/2019 17:30:07
We all know V = IR Gary, and they are rated 0.020A or 20ma for your calculation
They are not bulbs as there is no filament, as they emit light when power is applied to the diode in the right direction
For polarity on an unmarked LED, look through it and you will see a large flag shape, that is minus,so follow that shape down for the negative connection
As a rule of thumb, you need 75 Ohms per volt protection
So 2v is in the order of 150ohms resistor
Another important point Gary is that the manufacturers normally recommend not bending the legs too close (3mm away minimum) as it can break the seal to the LED, or in the worse case the wires may snap off, as these days they are made of steel, which is not as malleable as older copper ones.
Barry
Posted by Barryorbik on 18/02/2019 17:23:16:
<snip/>
... I am sure some kind person will calculate the resistor value and Wattage rating for you.
Barry
Um...
An example showing my working method.
From the spec of the led find the forward voltage drop and the working current.
The volt drop is the voltage change across the led when it is shining. It varied depending on the colour and brightness of the led.
The current rating will be higher for brighter leds.
Lets call the volt drop D. It will be about 2.0V
A typical led will be rated at 15mA that is 0.15 Amps Lets call it I
What is your battery voltage? Lets call it Vb, and I'll pretend that it is 12volts
The resistor needs to ensure that the led gets the correct voltage across it.
The led is dropping D volts, so the resistor needs to drop Vb -D volts.
Dear old Ohms law says
V = I R The voltage (in Volts) across a resistor equals the current (in amps) multiplied by its resistance(in Ohms)
Reorganising this gives us
R = V / I
The volt drop across the resistor is Vb - D, so
R = (Vb - D) / I
which with our numbers is
R = (12 - 2) / 0.15 = 66.6 ish Ohms
OK?
Plummet
Once again you guys are great, all the answers I needed right there. Electrics of any sort is like black magic to me.
I have gone to the darkside and building a Tamiya truck for my grandson. Tamiya do a sound/light unit but I have read you can get better and cheaper. The sound side I have worked out,just lights now.
I do not know what voltage the leds need to be BUT it will run at 7.2/8.4v 6 cell nimh packs.
Rather than run several bulbs this unit can vary the voltage to the led so one bulb can be dipped ,main and high beam.If I have read correctly. still trying to find mention of led voltage needed.
Posted by Denis Watkins on 18/02/2019 18:11:14:
Plummet,
666 ohms, as the 0.15 should be 0.015A
Noughts always get me too
Ta,
Expletive!
Of course, instead of using Amps and Ohms you can use mA and kOhms and the sums come out correctly usually without the pesky decimal points.
Plummet
