old nieuport 17 model
tony oneill 1
Hi all, i bought an old nieuport 17 model at an auction and decided to try and get it flying. i had to strip some old covering off and as a temporary measure i replaced it with what i had laying around until i get it flying properly. in the meantime would anyone know where the C of G is on a model like this? its about 1.1m wide, just under 1m long and is fitted with an electric motor, similar to a ripmax quantum 2 .40 equivalent. I tried a 14.4 4 cell battery but this seem too large and heavy so i was going to try an 11 volt 3 cell instead.
would the C of G be a point between the ends of the main spar but in the center of the wing? which would put it at a point near the back of the wing above the cockpit. it does have a sweep on the main wing.
tony.
On the Radio Modeller Plan version, RM149, designed by my old Clubmate Eric Robinson, the CG is about 75% of the shortest point on the upper wing centre chord.
The semi-circular central cut-out on the trailing edge of the wing means it would be about 60% of the chord if there was no cut-out & also corresponds to the leading edge of the lower plane.
