iawnski Posted September 16, 2008 Share Posted September 16, 2008 hi all i need a little advise from the boffs on her ,well as you no im trying my hand at electric,got the plane, got the lipo , new lipo charger on tits way (thanks timbo )recomened.well speed controler is a super simple 40 amp,with no instructions ?how the hell do you programe it for a 2000 mah 7.4 lipo,anyone had one of these did you have instructions ?need your help people Quote Link to comment Share on other sites More sharing options...
Frank Skilbeck Posted September 16, 2008 Share Posted September 16, 2008 It should automatically recognise the number of lipo cells. Programming would let you set type of cell (e.g. Lipo, Mimh), motor timing etc. I got a cheap 30A from hobbycity no instructions but the Turnigy programming card works with it. Quote Link to comment Share on other sites More sharing options...
iawnski Posted September 17, 2008 Author Share Posted September 17, 2008 cheers frank just orderded a card hope its simple Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted September 17, 2008 Share Posted September 17, 2008 I am not sure that the card will work the "super simple" ESC some Turnigy cards work so it may be fine. I can tell you that the ones I own do NOT auto detect the cell count however things may have moved on - mine are 6 months old!! I did here that they default to 3s pack, so if you plan on using a 2s ( which I think you do ) then it WILL need adjusting or else you will find it cutting power to the motor at far too high a voltage. Ideally you need the LVC to activate at around 5.5V on a 2s pack under load. However, as i say yours may be different and auto detect - just leaving the option to programme it for either LiPo detection on or off, and brake settings. Normally you would set brake to OFF unless you are using a folding prop and wish it to fold rather than feather in flight when you chop the throttle. Anyway, I have the PDF document of the manual here so will forward a copy on to iawnsk. Alternatively kev take a look at this here as it might the same as yours.PS sorry, but, despite the name, I can guarantee that things with electric flight are never simple Quote Link to comment Share on other sites More sharing options...
iawnski Posted September 17, 2008 Author Share Posted September 17, 2008 cheers tim thanks for that will wait for it to come and check it out. Quote Link to comment Share on other sites More sharing options...
Frank Skilbeck Posted September 17, 2008 Share Posted September 17, 2008 OK my 30A supersimple ESC is only 1 month old, it may default to a 3s as that is what I'm using it on so I can't comment on other cell counts. But the Turnigy programming card worked on mine. Quote Link to comment Share on other sites More sharing options...
