Bob Sims Posted July 22, 2019 Share Posted July 22, 2019 Hi all I wonder if there is some out there that can please help me. I am trying to bind an orange R618 XL to the jumper The rx binds OK but the throttle on the RX moves with the Elevator stick on the TX. I use Mode 2 and TAER on the TX. It looks like airelon and throttle are back to front .What am I doing wrong? thanks Bob Edited By Bob Sims on 22/07/2019 14:09:29 Edited By Bob Sims on 22/07/2019 14:13:34 Edited By Bob Sims on 22/07/2019 14:13:59 Quote Link to comment Share on other sites More sharing options...
Don Fry Posted July 22, 2019 Share Posted July 22, 2019 You have the throttle servo plugged into the elevator plug of the RX. Quote Link to comment Share on other sites More sharing options...
Bob Sims Posted July 22, 2019 Author Share Posted July 22, 2019 Hi Don Just done another check Rudder(left stick left right) on TX moves Rudder on RX Throttle on TX (left stick up/down) moves Aileron on RX Aileron on TX (right stick left/ right) move elevator on RX Elevator on TX (right stick up/down moves Throttle on RX Quote Link to comment Share on other sites More sharing options...
Don Fry Posted July 22, 2019 Share Posted July 22, 2019 Ok, rudder servo is good. Throttle stick servo output on RX has the aileron servo plugged into it. Move the throttle servo to this output. Aileron stick servo output on RX has the elevator servo plugged into it. Move the aileron servo to this output. Then the elevator servo goes into the spare output of the four main channels. Sometimes the standard outputs of a set of non manufactures units have a different order, and so the printed channel outputs on the RX are wrong. If you are it's a pickle to sort out. But the rule is, what the transmitter says is its output, is its output. Its the boss. I think I've got the above right, but it's a brain bender imagining it. Trial and error works until it is right. Edited By Don Fry on 22/07/2019 15:14:33 Edited By Don Fry on 22/07/2019 15:15:22 Quote Link to comment Share on other sites More sharing options...
Bob Sims Posted July 22, 2019 Author Share Posted July 22, 2019 Thanks Don I got it I changed the TX to AETR I must have changed it by mistake Thanks Bob Quote Link to comment Share on other sites More sharing options...
Don Fry Posted July 22, 2019 Share Posted July 22, 2019 Arrrr, I've just looked up what your Tx is. It's complicated to do all those things. Quote Link to comment Share on other sites More sharing options...
Richard Long 2 Posted October 11, 2019 Share Posted October 11, 2019 You've done nothing wrong. The channel order for Jumper is AETR even when binding to a Spektrum. You get round it by either remapping your channels to another order such as TAER (Spektrum) or reorder the plugs in your receiver to match the channels. Quote Link to comment Share on other sites More sharing options...
Bob Sims Posted October 12, 2019 Author Share Posted October 12, 2019 Thanks Richard Bob Quote Link to comment Share on other sites More sharing options...
Phil Green Posted November 23, 2019 Share Posted November 23, 2019 Remember though you must use TAER with the cheaper receivers that have failsafe only on channel 1 Quote Link to comment Share on other sites More sharing options...
Mike Blandford Posted November 24, 2019 Share Posted November 24, 2019 Assuming you are using the multi-protocol module on the T16, this has most likely got automatic channel re-mapping in it. What this means is you (always) set the Tx to AETR. The module then changes this order depending on the protocol it is using. For Spektrum (and compatibles) this is TAER. So, with the Tx set to AETR, you should find the throttle is output on channel 1 of the Rx, Aileron on 2, Elevator on 3 and Rudder on 4. Mike Quote Link to comment Share on other sites More sharing options...
