Graham Cramp Posted August 22, 2019 Share Posted August 22, 2019 Good day all, Quick question regarding the two above engines. I'm intending to begin a build soon from a slightly older plan which requires an OS Max 25FP. This is a discontinued engine and I was wondering how the ASP 21 compares. I know OS have a more recent alternative, but i want the round cylinder head as I want to replicate to give the illusion of a replica radial engine. Thanks in advance Quote Link to comment Share on other sites More sharing options...
Dave Cunnington Posted August 22, 2019 Share Posted August 22, 2019 Graham PM sent Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted August 22, 2019 Share Posted August 22, 2019 These are ballpark figures from my notebook Graham But I made a similar comparison for a small Hobbyking Edge conversion and chose the ASP 21 as the numbers added up I have a note of the ASP21 giving 550W top end and the OS25 at 600W top end These numbers are from my notebook so no science involved The ASP21 is very loud, so consider an add on silencer, or in my case, I unbolted the existing silencer and added another 1" of pipe Edited By Denis Watkins on 22/08/2019 11:23:48 Quote Link to comment Share on other sites More sharing options...
Jon H Posted August 22, 2019 Share Posted August 22, 2019 I would expect the ASP to beat the 25fp. The 25fp was a great engines but it was a plain bearing engine with (if i remember rightly) cross flow porting. It was never a powerhouse. The ASP 21 is ballraced with a much higher performance porting setup and larger carb. It is likely to offer similar or greater performance even with the smaller capacity. Both engines are loud by modern standards on stock silencers but that can be easily corrected. Quote Link to comment Share on other sites More sharing options...
Braddock, VC Posted August 22, 2019 Share Posted August 22, 2019 25FP were schneurle ported but no great shakes, even on 15 or 20 % nitro, best easily obtainable 21 by a country mile is/was the irvine 20. There are more powerful ones but asp isn't one of them and cost could become an issue. The silencers of most 21s leave a lot to be desired. Back to the OP the asp is a better bet than the 25 FP unless you already have an FP as they are good reliable engines with an OS no 8 plug and probably suited to your model if the design recommends it. FWIW OS claimed a much higher output than was good for them for the FP series, in real terms the asp is about 15% more powerful and 15% more noisy, especially if the the os was fitted with the super silencer. I have the 25FP, the OS 25 FSR and the Irvine 20, the fsr leaves them all for dead but they are a bit like rocking horse poo at present. Quote Link to comment Share on other sites More sharing options...
Jon H Posted August 22, 2019 Share Posted August 22, 2019 Posted by Braddock, VC on 22/08/2019 13:05:40: 25FP were schneurle ported but no great shakes Ah fair play, i thought the fp35 was crossflow and by extension the 25 but i could have been thinking of the earlier max series as i know they were crossflow. Its been some time since i dismantled any of them. I think all of mine are sat unloved in a drawer somewhere. Quote Link to comment Share on other sites More sharing options...
Graham Cramp Posted August 22, 2019 Author Share Posted August 22, 2019 Thanks for the replies everyone. I had thought that the ASP would likely be similar in performance but had nothing technical to back it up. Might noise be an issue... maybe... do I make it an electric setup...? I'm just not sure I could to that to myself! Thanks again everyone! Quote Link to comment Share on other sites More sharing options...
Peter Christy Posted August 22, 2019 Share Posted August 22, 2019 If noise is an issue, Just Engines do a range of "quiet" and "super-quiet" silencers for small 2-strokes. They have the OS fitting dimensions, but will also fit the clones, such as ASP. **LINK** -- Pete Quote Link to comment Share on other sites More sharing options...
Nigel R Posted August 22, 2019 Share Posted August 22, 2019 "i thought the fp35 was crossflow and by extension the 25 but i could have been thinking of the earlier max series as i know they were crossflow" All FP were Schneurle, but without the the boost port, I believe. They started off as cast iron and then went to ABN. I read a rumour the ABN types had slightly larger ports and consequently a bit more beans. Just to confuse things, OS labelled all sorts of their 2 strokes "max" at various points! Those JE silencers look suspiciously like ASP items - get them while you can. Quote Link to comment Share on other sites More sharing options...
GONZO Posted August 22, 2019 Share Posted August 22, 2019 As a point of interest the piston/liner set from the Thunder Tiger 25GP is an exact fit in the OS 25FP and has a boost port. I have two OS 25FP so modified, as yet un run. Everything else also appears to be interchangeable. My TT 25 GP turns a master 9X6 @12,000rpm on 10% fuel. Quote Link to comment Share on other sites More sharing options...
Nigel R Posted August 23, 2019 Share Posted August 23, 2019 And the Magnum/TT GP were true ABC vs the OS ABN. Quote Link to comment Share on other sites More sharing options...
GONZO Posted August 23, 2019 Share Posted August 23, 2019 Quote Link to comment Share on other sites More sharing options...
