A short tutorial in electric motor timing required!
Having used some of the larger electric outrunner motors and noticed that for instance the Hacker A100-8 and A100-10 quote the timing recommended at 22 degs. However, I have a similar sized outrunner from Turnigy (100cc equivalent) with no information or manual with it. Changing the timing with my Hobbywing OPTO esc is straightforward (defaulted at 15deg with a 0-30deg range possible.) Short of experimenting with various timings I can see no other way of find out what the ideal timing should be. Certainly the number of poles on the Turnigy is likely to be 20+ I would imagine. Thanks.
