Andy J Posted September 17, 2019 Share Posted September 17, 2019 A little of subject but sue its all semi related as 3D printing must start with a CAD drawing. Anyway using FreeCad V18 to draw some small ribs which I need cutting. Unable to get the package to output a viable drg file to send to the laser cutting supplier. Has anyone had these type of issues before? Andy Quote Link to comment Share on other sites More sharing options...
Christopher Long 1 Posted September 17, 2019 Share Posted September 17, 2019 Why not export or save the drawing in .dxf ? - most laser cutter services will accept .dxf files (well all of the ones I have used). Chris Quote Link to comment Share on other sites More sharing options...
Broken Prop Posted September 18, 2019 Share Posted September 18, 2019 What Christopher says is quite true but unfortunately not all dxf files are the same. If the laser cutter is relatively new it should be able to cope, but if the machine is old it may not read all of the lines in a drawing as it will be set up to read dxf in AutoCad 2000 or something of similar vintage. It would be worth enquiring at the laser cutting company. Also look in the 'Save' part of your program where you may find a choice of AutoCad file to save. Others may be more familiar with FreeCad V18 and can advise further. Pete Quote Link to comment Share on other sites More sharing options...
Andy J Posted September 18, 2019 Author Share Posted September 18, 2019 Well looked again at what I sent to the cutting company and it was a .dxf. May well have to try to find some other cutting company that will handle other formats other than dwg or .dxf. Any recommendations? Quote Link to comment Share on other sites More sharing options...
