Paul Marsh Posted September 22, 2019 Share Posted September 22, 2019 Bought this model for £5 with a rusty OS 46 AX engine. THought the engine was scrap.but did have a silencer which is over £20. Servos work, but cleaned engine, and not as bad as was envisaged. Engine was not siezed, car and crank shaft turns over. Needs a prop driver thrust washer, just ordered. Quote Link to comment Share on other sites More sharing options...
Paul Marsh Posted September 22, 2019 Author Share Posted September 22, 2019 Found this pic, deleted the pic of the kid just in case, the only photo I could find. Edited By Paul Marsh on 22/09/2019 18:58:59 Quote Link to comment Share on other sites More sharing options...
Kevin Fairgrieve Posted September 22, 2019 Share Posted September 22, 2019 Tis a Gremlin. I love mine. Full specs etc here.Combat Gremlin I have the plan as a PDF if you want a copy. I had severe elevon flutter on mine. Check out this video. First instance at about 2.35 mins in. Cured with a strip of "blenderm" over the hinge joint. Power from a very old worn out Thunder Tiger GP.42. Edited By Kevin Fairgrieve on 22/09/2019 19:43:58 Quote Link to comment Share on other sites More sharing options...
Paul Marsh Posted September 22, 2019 Author Share Posted September 22, 2019 Thanks, I've ordered a thrust washer and spacer, and will make a set of fins up tomorrow. Looks an ideal chuck model for winter and fun, for £5! Quote Link to comment Share on other sites More sharing options...
Paul Marsh Posted September 23, 2019 Author Share Posted September 23, 2019 Well, the engine runs ok, so that is usable. Quote Link to comment Share on other sites More sharing options...
Paul Marsh Posted September 24, 2019 Author Share Posted September 24, 2019 Finished Gremlin combat aircraft. Fitted the rest of the gear, and added some fins. They are removable with screws so can be swapped without glue. Quote Link to comment Share on other sites More sharing options...
Steve Houghton 1 Posted September 24, 2019 Share Posted September 24, 2019 It reminds me of the control line combat models I flew as a kid in the 70's. Quote Link to comment Share on other sites More sharing options...
Toni Reynaud Posted September 24, 2019 Share Posted September 24, 2019 I remember a flying wing I made back in the early 80's, powered by a Webra Bully. Lovely and stable at first, then and the fuel was used up and the balance point moved back it got VERY sensitive. Great fun, but I had reflexes back in those days. Quote Link to comment Share on other sites More sharing options...
Kevin Fairgrieve Posted September 24, 2019 Share Posted September 24, 2019 Posted by Paul Marsh on 24/09/2019 13:38:30: Finished Gremlin combat aircraft. Fitted the rest of the gear, and added some fins. They are removable with screws so can be swapped without glue. On mine and on the plan it shows the fins angled out. I used a bit of trailing edge. I am sure it will fly as it is, but you never know. Mine fins are also bolted on for knock off ability. So far not required. 82. My old 35mhz channel frequency. Quote Link to comment Share on other sites More sharing options...
Paul Marsh Posted September 25, 2019 Author Share Posted September 25, 2019 ++++Stop press++++ As there was a break in the weather, decided to go for a fly. So flew the Gremlin, did an underarm chuck and flew no problem. a couple of clicks down trim and tracks well in the air. Although quite heavy, doesn't seem that was in flying characteristics. Quote Link to comment Share on other sites More sharing options...
Kevin Fairgrieve Posted September 25, 2019 Share Posted September 25, 2019 Forgot about this video. How much fun can you have with 15 or so gremlin type planes? Edited By Kevin Fairgrieve on 25/09/2019 18:51:19 Quote Link to comment Share on other sites More sharing options...
