Rich too Posted September 29, 2019 Share Posted September 29, 2019 On advice I have purchased one of these for a petrol model. I need to assemble it but there are no instructions. Does the carb line just go in the middle of the cap? Do the two nipples go anywhere on the tank (top), and do I have to use any type of sealant? cheers Quote Link to comment Share on other sites More sharing options...
Engine Doctor Posted September 29, 2019 Share Posted September 29, 2019 The fuel supply to carb goes on the cap . the other two nipples are a filler/drain and a breather and can be fitted in any suitable side of the tank. . No sealer should be required if parts are seated correctly ,just snug them up with correct spanner. Tip when you run the breather tube out of the model insert a piece of tube that is crimped with a pin in it . remove the pin and this will allow tank to breath but reduce any spills Quote Link to comment Share on other sites More sharing options...
Rich too Posted September 29, 2019 Author Share Posted September 29, 2019 Thanks ED. It just occurred to me, How do you get the nut on the inside Quote Link to comment Share on other sites More sharing options...
bert baker Posted September 29, 2019 Share Posted September 29, 2019 Put a bit of soft wire or solder through the tank and slide the bits into position on the wire Quote Link to comment Share on other sites More sharing options...
Rich too Posted September 29, 2019 Author Share Posted September 29, 2019 Posted by bert baker on 29/09/2019 11:06:35: Put a bit of soft wire or solder through the tank and slide the bits into position on the wire how do you hold them to tighten? And presumably the washers go on the inside? apologies for all the questions Quote Link to comment Share on other sites More sharing options...
bert baker Posted September 29, 2019 Share Posted September 29, 2019 Oh put the nuts on the out side Quote Link to comment Share on other sites More sharing options...
bert baker Posted September 29, 2019 Share Posted September 29, 2019 Your not bolting the Fourth bridge ,,, don’t over tighten or you may cut a hole in the tank . Just nip it up. could use pliers on the barb of the nipple just don’t sqash it or snag it Quote Link to comment Share on other sites More sharing options...
Rich too Posted September 29, 2019 Author Share Posted September 29, 2019 Of course I should have taken them out of the packet and had a look - bit of a hangover ps I was stupid enough to camp at Brands Hatch last night with a few mates Edited By Rich too on 29/09/2019 11:22:44 Quote Link to comment Share on other sites More sharing options...
bert baker Posted September 29, 2019 Share Posted September 29, 2019 That’s silly as it’s been raining Quote Link to comment Share on other sites More sharing options...
Rich too Posted September 29, 2019 Author Share Posted September 29, 2019 Yep and we felt the full force of it all night and I don’t like camping at the best of times Edited By Rich too on 29/09/2019 11:41:52 Quote Link to comment Share on other sites More sharing options...
bert baker Posted September 29, 2019 Share Posted September 29, 2019 Went there thirty years ago to a Firework night got towed out by a tractor never been back Quote Link to comment Share on other sites More sharing options...
