john stones 1 - Moderator Posted October 12, 2019 Share Posted October 12, 2019 Fitting my switches in a petrol model, logical and tidiest place has them close to the ignition unit ? RX is placed as far away as possible, am I o.k, or do I need to move switches location ? Quote Link to comment Share on other sites More sharing options...
Richard. W. Posted October 12, 2019 Share Posted October 12, 2019 I'd say you were fine to fit them. As long as the rx is away from the ignition, the switch placement shouldn't matter. I have a petrol plane with the switches very close to the ignition and have no problems. Quote Link to comment Share on other sites More sharing options...
Don Fry Posted October 12, 2019 Share Posted October 12, 2019 I looked at.this thread earlier. My first thought was no, put the switch and it's wires back away from the interference source, then I thought, why do you think no, and I had no answer, so I shut up. Can anyone do a bit of a technical answer to the question. Quote Link to comment Share on other sites More sharing options...
Geoff S Posted October 12, 2019 Share Posted October 12, 2019 If the wiring and switches is very close to the igntion and the high voltages (ie 1000s of volts) are inadequately screened then it's possible interfering voltage spikes could be induced into the wiring and on to the receiver etc. It may be or not be a problem and you could be OK but it's better to route any wiring connected to the electronics away from potential interference sources. If it's not too much of a hassle I'd move the switchs away from the ignition unit just to be on the safe side. Your choice but do a thorough range check before flying with the engine running. Geoff Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted October 12, 2019 Author Share Posted October 12, 2019 Cheers folks, never heard of it as a problem, but if I have to move them, there's holes to refill, I'll put em further away and settle for that. Quote Link to comment Share on other sites More sharing options...
Rich too Posted October 13, 2019 Share Posted October 13, 2019 Hi John, on all my petrol models the ignition unit is generally mounted on the outside of the engine box, and the receiver and switch way back, near the wing tube. Never had interference... Quote Link to comment Share on other sites More sharing options...
Peter Christy Posted October 13, 2019 Share Posted October 13, 2019 Are we talking about ignition switches or radio switches? I would always recommend keeping anything connected to the receiver as far away as possible from ignition circuits. Of course, this isn't always possible and anyway, modern 2.4GHz gear is generally less susceptible to ignition noise than 35 MHz gear. However, it never does any harm to keep the receiver and its associated wiring as far away from sources of interference as you can manage. Don: Guess you made it back to France OK? Good to catch up with you on Friday! -- Pete Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted October 13, 2019 Author Share Posted October 13, 2019 Not a big enough model to do that Rich, it's Seagull Funky Cub, units at side of tank. Went with ignition switch up front and rx switch at back of cabin, be a faff turning on/off but best way I reckon. Quote Link to comment Share on other sites More sharing options...
