StefanoL Posted October 12, 2020 Share Posted October 12, 2020 I am looking for a 3S2200 battery for a new Easyglider 4. The connector is MPX. Multiplex recommends its 20C Roxxy Evo and I am wondering if an alternative could also work, besides being cheaper. Say, a HK Turnigy 25C, 30C or 40C. In that case, I would also need a XT60 (or other connector) to MPX adapter. What would you recommend, the more expensive Roxxy or a Turnigy (which discharge?) with adapter? Quote Link to comment Share on other sites More sharing options...
ken anderson. Posted October 12, 2020 Share Posted October 12, 2020 hello Stefanol and welcome.dont go paying for expensive lipo's,your easyglider will be quite happy with the brands you mention and perform exactly the same......you may need to solder on different connector's. ken anderson...ne..1..battery dept. Quote Link to comment Share on other sites More sharing options...
StefanoL Posted October 12, 2020 Author Share Posted October 12, 2020 Posted by ken anderson. on 12/10/2020 13:16:37: hello Stefanol and welcome.dont go paying for expensive lipo's,your easyglider will be quite happy with the brands you mention and perform exactly the same......you may need to solder on different connector's. ken anderson...ne..1..battery dept. Thanks Ken. Will Turnigy 25C be enough given that the recommendation was 20C? I've read somewhere here that C-rates must be taken with a grain of salt, due to different measurement practices at the manufacturers. Quote Link to comment Share on other sites More sharing options...
ken anderson. Posted October 12, 2020 Share Posted October 12, 2020 yes, the 25C battery's will do the trick no problem...…...bearing in mind the fight pattern of the E/G.....its a very gentle model not a pylon racer...send me any dosh you save...thanks. ken anderson...ne...1.saved dosh dept. Quote Link to comment Share on other sites More sharing options...
Shaun Walsh Posted October 12, 2020 Share Posted October 12, 2020 Adapter here: Adapter Quote Link to comment Share on other sites More sharing options...
