001 Posted October 17, 2008 Share Posted October 17, 2008 I bought a Corona 8 Channel 35 MHz receiver a few months ago and have been very pleased with it. SoThis week I bought a Corona RP4Si Synthesised receiver from HK. Firstly there were no instructions at all, easily remedied by downloading them (unfortunate situation for those buyers without internet access). I spent about an hour trying to get it to lock on to the transmitter. Nothing doing, so I tried another crystal, different channel, in the Transmitter, a common Futaba. Nothing. Then I picked the receiver up and the aerial fell off. It had apparently been only supported by melted insulation. So it is going back! If you do buy one of these beware, but dont tug on the aerial with any force as it is very thin. Probably best to double it back and secure the first inch or so to the receiver case with tape. Quote Link to comment Share on other sites More sharing options...
Ultymate Posted October 17, 2008 Share Posted October 17, 2008 The Corona crystal controlled R/Xs have a brilliant reputation but the synthesised ones are getting very bad press, many like yours and others that simply will not lock onto the T/X signal. Rumour has it that their recently released 2.4 Gig system just will not work at all Quote Link to comment Share on other sites More sharing options...
Bob Cotsford Posted October 19, 2008 Share Posted October 19, 2008 I've got two RP4SI's, both lock on easily - tx aerial up, switch on the rx, press the button twice as per instructions and they lock on. They do take a few seconds to initialise themselves on switch-on, but reaquire the tx immediately if the signal is lost - I tested by switching the tx off for a few seconds.Maybe I've been lucky? Quote Link to comment Share on other sites More sharing options...
Bruce Richards Posted October 19, 2008 Share Posted October 19, 2008 I agree with bob. I did not know you had to press the button twice but I have still got successful lock with 2 different Futaba Txs just by fiddling about until it works. Quote Link to comment Share on other sites More sharing options...
Brian Parker Posted October 19, 2008 Share Posted October 19, 2008 Agreed. The RP4SI is a great little receiver. I have used one in a small model for some time with no problems with both JR and Futaba Transmitters on different frequencies (requires the resetting of the frequency each time I change transmitter, but just a needs a couple of presses of the button). It does, as stated earlier, take a couple of seconds to ‘lock’ onto its ‘set’ transmitter when switching on but remains locked throughout with no glitching and has survived my less that gentle arrivals. With a range of around one mile it has to be good value.PS. The correct frequency setting procedure (if you haven’t the data sheet) is…Transmitter on, mode PPM, receiver/model close to the transmitter, connect receiver battery, let the LED flash twice, press button for two seconds, release, press again, the LED will flash then stay on….locked on the frequency. Range check and off you go. Quote Link to comment Share on other sites More sharing options...
Phil_G Posted November 25, 2008 Share Posted November 25, 2008 Corona RP4S1 mini-Review Quote Link to comment Share on other sites More sharing options...
Steve Hargreaves - Moderator Posted November 28, 2008 Share Posted November 28, 2008 I had a similar problem with the synthesised Rxs from Corona. They just wouldn't see my (Futaba) transmitters.....I sent them back & apparently they checked out OK.....I have several of the crystal controlled Rxs & think they are great little units.....no problems at all but I do agree with Richard about the aerials.......a bit flimsy to say the least Quote Link to comment Share on other sites More sharing options...
