Simone Perfetti Posted January 31, 2021 Share Posted January 31, 2021 I would show my current project, Edf Eagle. I'm building an eagle with balsa and plywood to create the molds with fiberglass/epoxy to make the model with a plywood/ composite structure with an edf inside the fuselage, The idea is to make a model with a wingspan of 120-130 cm with divided wings for an easy transport and less than 900grams of weight to achieve good gliding performance with the motor turned off and the possibility of aerobatic flight and recover altitude with the edf turned on. I will install an air inlet that opens when the edf is running and closes when the edf is off to reduce the air resistance during the gliding flight, Currently I'm modifyng the wings and tail to be more realistic and gives to the model more yaw stability Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted January 31, 2021 Share Posted January 31, 2021 Excellent work Simone, I cannot wait to see the finished Thing. Very good. D.D. Quote Link to comment Share on other sites More sharing options...
Roger Jones 3 Posted January 31, 2021 Share Posted January 31, 2021 That's terrific! Good idea about the intakes. Quote Link to comment Share on other sites More sharing options...
Simone Perfetti Posted February 1, 2021 Author Share Posted February 1, 2021 Thank you! I hope to finish it during this winter Quote Link to comment Share on other sites More sharing options...
Stephen Jones Posted February 1, 2021 Share Posted February 1, 2021 You maybe interested in this Eagle it is tailless just like a real bird.. Also you can download his plan. Steve Quote Link to comment Share on other sites More sharing options...
Simone Perfetti Posted February 3, 2021 Author Share Posted February 3, 2021 Thanks Steve, interesting, I' m making my model tailless too Quote Link to comment Share on other sites More sharing options...
