Andy Harris Posted October 26, 2008 Share Posted October 26, 2008 I got my sone one of these whilst on holiday in the States.He's 'pre-A' test at the moment and the T28 is perfect to practice landings with.It had a very hard knock due to a 2.4G problem but back in the UK the spares are cheap and easy find. I'll convert it to 35MHz so it can continue its role. Quote Link to comment Share on other sites More sharing options...
Phil Claridge Posted October 26, 2008 Share Posted October 26, 2008 hi andy i fly one of these and found it needed a tough more down thrust this was done by putting a washer under the top motor mount bolt . mine dosent need nose wieght, i use zippy 2200mah 3s1p 8d 2o-30c lipos these are advertiesed in this months mag and they fit perfectly keep them pushed forword as far as they will go,there is very little change in the cog using these batts and they are cheapi can get 20 mins with varied flying . the trojan is now my favorite plane becuase ican chuck it in the car and go flying anytime phil Quote Link to comment Share on other sites More sharing options...
David Ashby - Moderator Posted October 27, 2008 Share Posted October 27, 2008 It's a great model - there are a few threads around here (probably in models and access') about the old T-28. Quote Link to comment Share on other sites More sharing options...
Tony Read Posted October 31, 2008 Share Posted October 31, 2008 Phil, are they the ones advertised by 'Go Brushless'? Did you change the connector on the Trojan or keep stock? Quote Link to comment Share on other sites More sharing options...
Phil Claridge Posted November 1, 2008 Share Posted November 1, 2008 tony i bought mine at hop farm and cant remember from which dealer the model is a PARKZONE T28 TROJAN i got mine for 115 quid the connector was changed to deans plug as i use them on all my lipos Quote Link to comment Share on other sites More sharing options...
