Cliff 1959 Posted April 2, 2021 Share Posted April 2, 2021 How do I set up the throttle to cut on Tx signal loss on the MZ24. I've set up a safety throttle cut off switch but that's not the same thing. Any ideas welcome? Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted April 2, 2021 Share Posted April 2, 2021 (edited) When you are Binding you Rx to your Tx do so with your throttle stick down Edited April 2, 2021 by Denis Watkins Quote Link to comment Share on other sites More sharing options...
Frank Skilbeck Posted April 2, 2021 Share Posted April 2, 2021 Reading the MZ24 manual, there is a specific failsafe settings menu where you select what the channel does on failsafe, So for the throttle channel, select this to go to failsafe and then just set the failsafe with the throttle cut active, all the throttle cut does is move the throttle signal to minimum, so if you set failsafe with the throttle cut active then on failsafe the receiver will instruct the throttle channel to go to this position. Quote Link to comment Share on other sites More sharing options...
Cliff 1959 Posted April 2, 2021 Author Share Posted April 2, 2021 (edited) Sorted Frank, thanks (club rules). Thanks Denis Graupner more complex!! Edited April 2, 2021 by Cliff 1959 Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted April 3, 2021 Share Posted April 3, 2021 Thanks Cliff 1959 This is now we learn everyday Denis 1951 Quote Link to comment Share on other sites More sharing options...
Frank Skilbeck Posted April 3, 2021 Share Posted April 3, 2021 9 hours ago, Cliff 1959 said: Sorted Frank, thanks (club rules). Thanks Denis Graupner more complex!! Having reviewed quite a few makes of transmitters, Graupner is no more complex than many others. You just have to know the system. But it does allow you to determine what you want each channel to do on a failsafe, hold or go to a set position and also how long to wait before going to failsafe. BTW setting a failsafe is a CAA requirement, and if fitted the throttle must go to minimum on loss of signal, as all 2.4 radios have a failsafe then it is important that it has been set and tested. Quote Link to comment Share on other sites More sharing options...
