SBEC
aquila
Hi,
I have an aether powered glider and the SBEC just stopped beeping between uses, it was OK the last time I used it about a weeks ago and then when I turned it on yesterday - nothing - the servos are all working so the power is getting through to it. I don't really understand any of the electronics so can anyone tell me, has it gone kaput/ or is there anything else I can try?
SBEC not beeping?  SBECs don't normally beep, so I presume you're talking about the ESC (Electronic Speed Controller) which usually beeps when it's powered up.  If so, lack of beeps usually means the motor has become disconnected, for it's actually the motor that's used as a loudspeaker when the ESC is beeping.  So check ESC-to-motor connections.
