Pete Barnes Posted November 10, 2008 Share Posted November 10, 2008 Hey fellow rcm&e-ers, the wind outside has been howling for days so im curing the boredom by showing off one of my hybrid hotliners, it started as a greatplanes siren but i lost the wing to flutter in a high speed dive and decided to knock up a shorter, faster stronger wing and smaller tail section, now its called the siren(ish). hotliners are starting to gain a cult status and im well chuffed when i see models like the blizzard appear on the market, i hope the popularity may long continue!! heres a quick vid i knocked up of the (ish) so please enjoy and lets talk about how great hotties are!Pete Quote Link to comment Share on other sites More sharing options...
Adrian Posted November 10, 2008 Share Posted November 10, 2008 Hotliners are great fun and they also ride the wind better than most other power models. Just be careful to keep below cloud base. BTW, I can't see your video. Quote Link to comment Share on other sites More sharing options...
David Ashby - Moderator Posted November 10, 2008 Share Posted November 10, 2008 Looks ok to me Adrian, seems to be working, anyone else have the same problem? Quote Link to comment Share on other sites More sharing options...
Former Member Posted November 10, 2008 Share Posted November 10, 2008 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Bruce Richards Posted November 10, 2008 Share Posted November 10, 2008 No video just a blank space where it should be in the post. Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted November 10, 2008 Share Posted November 10, 2008 ditto no video just a white square. Thats what I usually get also when I try and link to Utube videos., never did get the hang of linking correctly to video, so now usually just paste the whole URL Quote Link to comment Share on other sites More sharing options...
flytilbroke Posted November 10, 2008 Share Posted November 10, 2008 Blank screen for me too. Quote Link to comment Share on other sites More sharing options...
260 Flyer Posted November 10, 2008 Share Posted November 10, 2008 Me no see! Quote Link to comment Share on other sites More sharing options...
Bob Cotsford Posted November 10, 2008 Share Posted November 10, 2008 blank in both IE and Firefox, and I have Flash 9.something installed. Quote Link to comment Share on other sites More sharing options...
David Ashby - Moderator Posted November 10, 2008 Share Posted November 10, 2008 Hang on, I thought Pete meant the video gallery? Pete - where are you trying to embed from? Can you paste the html and I'll have a go... Quote Link to comment Share on other sites More sharing options...
Pete Barnes Posted November 10, 2008 Author Share Posted November 10, 2008 Hi dave i just tried to paste in the url from you tube, any ideas? untill its sorted tho type the siren(ish) into youtubes search and there she'll be, i hope... Quote Link to comment Share on other sites More sharing options...
260 Flyer Posted November 10, 2008 Share Posted November 10, 2008 PeteHave you seen this? Quote Link to comment Share on other sites More sharing options...
Pete Barnes Posted November 10, 2008 Author Share Posted November 10, 2008 the siren(ish)thanks for your help guys im a newcomer!!!pete Quote Link to comment Share on other sites More sharing options...
260 Flyer Posted November 10, 2008 Share Posted November 10, 2008 That's an impressive rate of climb! Quote Link to comment Share on other sites More sharing options...
Pete Barnes Posted November 10, 2008 Author Share Posted November 10, 2008 I have decided its going to go faster still, it is currently sitting on the worktop in a most undignified manner with a semi inflated, erm ... balloon in the forward fuse section which is sealing in a few more carbon strips for added rigidity, might be overkill but a 2kw Neu f5b motor does have some kick to it!Im almost sure that the wing wont cope so i have "borrowed" a proven 10% rg15 1700mm foam core wing from another hotliner and already started cutting the channel for the roved carbon spar to sit in, one day ill have the skills to mould up a wing from scratch but till then i shall make do with what i have (and what i can borrow!) i will upload some pictures as soon as i can figure out how to resize the images for uploadPete Quote Link to comment Share on other sites More sharing options...
Pete Barnes Posted November 10, 2008 Author Share Posted November 10, 2008 Thanks for the info Eric ill get on the case Pete Quote Link to comment Share on other sites More sharing options...
Pete Barnes Posted November 11, 2008 Author Share Posted November 11, 2008 photo 1 Quote Link to comment Share on other sites More sharing options...
Former Member Posted November 11, 2008 Share Posted November 11, 2008 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Pete Barnes Posted November 11, 2008 Author Share Posted November 11, 2008 Im not sure where im going wrong with the photobucket, there are four codes under the image and i am pasting the img thumb code, I.T seems to have something against me! Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted November 11, 2008 Share Posted November 11, 2008 Pete - I have had to delete your post above as it made the page un-readable - have you seen this ?In photobucket you left click " direct link" and then in your posting, you click the "chain symbol" and right click your mose and hoose "paste" where it ask for the URL. Add some text in the box where it says "title" to describe the linked item. Quote Link to comment Share on other sites More sharing options...
260 Flyer Posted November 11, 2008 Share Posted November 11, 2008 Just left click on the last box IMG Code and a box will pop-up and say copied Then simply paste the code into the ModelFlying reply box. Quote Link to comment Share on other sites More sharing options...
260 Flyer Posted November 11, 2008 Share Posted November 11, 2008 P.SIf all goes wrong and you post a link as long as my model building wish-list, you had better delete it sharpish before Timbo spots it! Quote Link to comment Share on other sites More sharing options...
