Kelly Posted November 19, 2008 Share Posted November 19, 2008 Help needed please, I have 2 Futaba 2.4 Tx's and a connecting lead. I set it up as per the instruction manual, the pupils Tx is not working.Can anybody talk me through the set up ,I must be doing something wrong? ,both Tx's work fine on their own. CheersKelvin Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted November 19, 2008 Share Posted November 19, 2008 I take it the slave unit is powered off before plugging in the buddy lead, and that you have assigned the correct master /slave switch on the master Tx? Quote Link to comment Share on other sites More sharing options...
Kelly Posted November 19, 2008 Author Share Posted November 19, 2008 Hi Tim,Yes it is powered off.Master/slave trainer function on on the master on,off on the slave.Set up everything as per the manual, slave Tx will not power up ?Puzzled?Kelvin Quote Link to comment Share on other sites More sharing options...
David McMullan Posted November 19, 2008 Share Posted November 19, 2008 Hi Kelvin,As the slave Tx is powered from the master Tx in buddy mode it sounds as if you might have a faulty lead. I had a bit of a problem with a "compatible" lead (poor soldering at the plug was to blame) binned it and bought a genuine Futaba lead. No probs after that.Dave Quote Link to comment Share on other sites More sharing options...
Kelly Posted November 19, 2008 Author Share Posted November 19, 2008 Hi Dave,It is a Futaba lead.Going to the model shop on Friday to replace my Boomerang, Will take the Tx's with me an let them sort it out.Kelvin Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted November 19, 2008 Share Posted November 19, 2008 Sorry couldnt help much more - I am JR / Spekky guy Quote Link to comment Share on other sites More sharing options...
Kelly Posted November 19, 2008 Author Share Posted November 19, 2008 Hi Tim,Thanks for trying,could be the cable ,find out on Friday Kelvin Quote Link to comment Share on other sites More sharing options...
David McMullan Posted November 23, 2008 Share Posted November 23, 2008 Hi Kelvin,What was the outcome on your Tx's?Dave Quote Link to comment Share on other sites More sharing options...
Kelly Posted November 24, 2008 Author Share Posted November 24, 2008 Hi David,Well I forgot to take them with me .Gave Seagull a second chance and purchased a Seagull 40 .I will post the outcome when I return to the shop in the near future.Kelvin Quote Link to comment Share on other sites More sharing options...
260 Flyer Posted November 25, 2008 Share Posted November 25, 2008 It could also be one of the sockets on the Tx's. I had to position the plug just right on my 6EX to get my flight sim to run. I tried another cable that worked perfectly on the FF7 but still had the same problem. After exchanging my Tx for the recall problem solved, but now I have an annoying "knock" n the aileron stick.Quality aint what it used to be! Quote Link to comment Share on other sites More sharing options...
Kelly Posted November 25, 2008 Author Share Posted November 25, 2008 Could well be Rob.The green light on the back of the master Tx flashes red and green instead of the steady green without the lead,same thing with the other Tx when I try that in the master mode.Looks like a cable or socket problem? Kelvin Quote Link to comment Share on other sites More sharing options...
Richard Duvall Posted December 10, 2008 Share Posted December 10, 2008 You have to activate the trainer function through the programming Quote Link to comment Share on other sites More sharing options...
