Kyosho spitfire 90
stuart macrory
Its probably covered in the same stuff as the 40 size, i have the 40 size Kyosho spit! The covering is shiny, so if you rough it up you should be able to work with it! I roughened up the bottom of mine and got some grey paint from warbird colours and sprayed with a airbrush! 3 months on so far so good! The guy who I got the paint from was very helpful and has all the colours you can think of and he was familiar with both the 40 & 90 size...
Hi Stuart, well if you fly off grass the small wheels dont like the grass, I had to put bigger wheels on mine and leave the gear down! I might take the gear doors off and try again with the small wheels!
However it does fly well and looks good in the air. I think Kyosho have phased out the one like mine which had the nasty blue on the underside? I did see some going really cheap. They have the Spitfire 50 out with both nitro and gas conversions. I guess for the price its a decent spitfire,  and it flies like a typical sport model.
Here's the new one
EP Kyosho Spitfire New Version
GP Kyosho Spit
On the 40 size Spit I have a 46 on board, wouldnt go less, 4s you would need a 70, a 54 hasnt got enough grunt, tried that on my Kyosho Mustang and both models are pritty much the same.
Would I get it? Yes
I will get some pics up of mine later after I have painted it etc..
Hope this helps?
dusty
Neil looks like the Kyosho guys in Germany are out of old stock and in with new, last i saw the same Spit as mine was 90euro with retracts, same Kyosho guy I got mine from is only selling the new version... oh well looks a good model (better looks than the mine) bet it flies a bomb as well as it looks!
