jockbarefit Posted August 3, 2023 Share Posted August 3, 2023 Hi, Starting out in R/C and looking for a charger for batteries (currently for Transmitter battery pack and Receiver batteries for Nitro Trainer but looking to move into LiPo etc. in the future) I have been offered a used GT Power C6D. Would this be suitable? I see some very inexpensive chargers on EBay from China, are these best avoided? Quote Link to comment Share on other sites More sharing options...
Flying Squirrel Posted August 3, 2023 Share Posted August 3, 2023 I don't have personal experience of them but I hear good things about the ToolkitRC charger... https://www.flyingtech.co.uk/accessories/toolkitrc-m9-600w-20a-1-8s-multi-function-smart-charger Quote Link to comment Share on other sites More sharing options...
Don Fry Posted August 3, 2023 Share Posted August 3, 2023 I’ve not used that charger, buts it’s a standard 4 button charger type that dominates the charger market. 4Max sells them for just under £40. Impeccable retailer, good reputation, does not sell rubbish. I say you will use that for ever, as you will always have a use. I would, if I were in the market for a 50 watt charger, not worry that I am buying rubbish. Cost is a condition of thing of course. Quote Link to comment Share on other sites More sharing options...
Simon Chaddock Posted August 3, 2023 Share Posted August 3, 2023 A normal 4 button charger. Understanding what the 4 buttons do and the sequences involved will probably be the biggest challenge. Read the manual. It has a built in mains transformer but can be also be run off a 12V supply. A max 6A charge rate up to a 6s LiPo should be adequate at least until you move onto big planes and want to charge multiple batteries simultaneously. It has NiMh and PB charge options as well. Normally these sort of chargers go on for years unless you get careless and accidently short something when connecting a battery. 😉 Quote Link to comment Share on other sites More sharing options...
Tom Gaskin 1 Posted August 3, 2023 Share Posted August 3, 2023 Welcome to the forum. Normally a 'wall wart' (a simple mains charger) will come with your RC gear. For the Lipos, most cheap chargers are 12 volts powered and so you will need either a mains power supply or a leisure battery. Some of the more expensive chargers will be dual-voltage so you can use it at home or at the field. Tom Quote Link to comment Share on other sites More sharing options...
KenC Posted August 9, 2023 Share Posted August 9, 2023 Hi, like you I have only used IC planes in the past and needed a Lipo charger and also wanted something that would charge NmHi flight packs and my 12 v starter lead acid. I opted for this one to get me started ToolkitRC M7AC 300W 15A AC/DC Balance Charger Discharger for 1-6S LiPo Battery With XT30 XT60 Output £47.86 X1 It was ordered from Bangood at the price shown and arrived in 10 days or so with import tax and delivery included in the figure. The charger runs on AC and DC in the field , charges every battery type you might want . Perhaps one day if I had lots and lots of Lipo batteries to charge I might go for a dual as well as this unit..... which by the way acts as a Servo tester and other stuff too ! So far I am very pleased . Oh yes I also bought two sets of cables to allow connection of the charger to every form of battery , from the same source. Quote Link to comment Share on other sites More sharing options...
