Roscoe Turner Special
Hello Golden Age racers....Fans.,  I build this famous  Laird Turner Meteor...PESCO SPECIAL  1938 version., fron Jim Young  T & J Models.,partial kits,  I build from conventional balsa and plywood ,construction . follows also for somes reference   RCM Modeler magazine plan NO:1112...the model have a wing span  51.5 inch., 490 sq.inch., I use natural solartex for  covering the  wing and the  rear section of the fuselage , with  a fews coats  (3)  of nitrade clear dope., for the front section of the fuselage  and cowl, I use 3/4 oz. fiberglass cloth with resine,. ,for solid rivets application details.,  for power-up I use a Scorpion 4025-10  515 kv., with 5-S 3,800 Lipo., with 15 X 8 prop.,  max. 50 amps., 900 watts.   model weight 6 popunds , for color I using automotive Dupli-color  lite slate met color., model with is set-up is blast the sky!...pretty fast...Happy flyig.....Cheers
  • Like 13
  • Thanks 1
On 05/07/2023 at 01:42, Chris Freeman 3 said:
Very nice models, love the looks of the classic racing aircraft. The Turner Special also looks very nice.     Thank Chris...
9 hours ago, Nigel R said:
Superb                 Thank Nigel...
12 hours ago, David Ashby - Moderator said:
Fantastic job.      Thank David..
