Steven Hurd Posted September 21, 2023 Share Posted September 21, 2023 Hi there Has anybody built the above Chris Foss kit, but built it with the wing options. I’m interested in thoughts on lightening the foam wing as per the option drawings, did it make a difference? And also the larger ailerons for “ sparkling roll rate” which involves cutting 1/2 inch off the rear of the wings trailing edge and then sticking a piece of 1/2 inch balsa to the aileron stock to make the ailerons larger. This seems a lot of work, but does it make a lot of difference to the roll rate etc, or is the roll rate ok without it? just looking for opinions before I start hacking into a perfectly good wing thanks steve 1 Quote Link to comment Share on other sites More sharing options...
Steven Hurd Posted September 26, 2023 Author Share Posted September 26, 2023 I’ll take this as nobody has tried the mods then. thanks for looking all the best Steve Quote Link to comment Share on other sites More sharing options...
Richard Harris Posted September 28, 2023 Share Posted September 28, 2023 Steve, One of my old clubmates who is no longer with us cut lightening holes into his taper winged WOT 4, it didn't seem perform any better than a solid wing so I'd question whether it is really worth the extra effort. I increased the area of the ailerons, elevator and rudder on my last WOT 4 and it did make a difference if you like lots of authority, that said this was on the parallel winged version which I prefer. Rich Quote Link to comment Share on other sites More sharing options...
Nigel R Posted September 28, 2023 Share Posted September 28, 2023 Holes are generally not worth the effort, in my experience... YMMV. Caveat - I have never built a wot 4 (although I have cut holes in things). Quote Link to comment Share on other sites More sharing options...
Steven Hurd Posted September 28, 2023 Author Share Posted September 28, 2023 Thanks for the input, I have had a weigh of the wings, and did a rough calculation of the weight against area of the material removed. My sums came to 1.25 ounces per wing, so I’m now clear that this would not really be worth the extra effort. May I ask Richard, when you made the aileron surfaces bigger, did you follow the option instructions of taking 1/2 inch off the back of the wing then adding the same to aileron? Or did you just make the surface bigger, I’ve looked at the wing and either would seem to work, but the latter would be a lot easier. thanks steve Quote Link to comment Share on other sites More sharing options...
