Nick Funnell Posted November 20, 2023 Share Posted November 20, 2023 Hi Im Looking for some help please looking to convert a greens tiger moth 78 inch wing span model to electric power. Can anyone recommend what size motor, esc, prop and battery size to use please Thanks in advance Nick Quote Link to comment Share on other sites More sharing options...
Alan Hilton Posted November 20, 2023 Share Posted November 20, 2023 Talk to or email 4max. George is good at this stuff .He needs to know weight span and ground clearance to be accurate Quote Link to comment Share on other sites More sharing options...
PeterF Posted November 21, 2023 Share Posted November 21, 2023 I have an 1/4 scale 88" span moth that is electric and very scale like, a bit larger than your but should provide some guidance. For things like loops it definitely needs a shallow full power dive first and happily flies for 15 minutes if I do not do too many aerobatics. Flying weight 18 lbs 2 oz inc batteries Motor Hyperion ZS4035-10 Kv = 354 (discontinued) 100A Hobbywing platinum ESC 2 x 6S Overlander 3900mAh Supersport batteries in parallel giving 7,800mAh @ 6S 18 x 10 wooden Falcon prop (scale diameter) With full batteries the set up runs at 6,400rpm and draws 1700W (81A @ 21V) This is about 95W/lb which is just right for scale like flight. Quote Link to comment Share on other sites More sharing options...
Nick Funnell Posted November 24, 2023 Author Share Posted November 24, 2023 Thanks Alan and Peter Quote Link to comment Share on other sites More sharing options...
