Tony Cooper Posted January 29, 2009 Share Posted January 29, 2009 I decided to have a go at building from a plan, and chose the Zulu E in Feb's RCM&E by Lindsay Todd The thrust line for the motor is not marked, at least I have not found it . If Lindsay or anyone could sugest where it should be, I would be obliged Edited By Timbo - Moderator on 28/03/2009 19:15:28 Quote Link to comment Share on other sites More sharing options...
Lindsay Todd Posted January 29, 2009 Share Posted January 29, 2009 Hi, with the number of motors around and the choice of props it can be difficult and it just got omitted. Basically the motor centre line is 25mm down from the top centre of the bulkhead, there is no need for any right thrust or down thrust. (basically the motor mounts central in the cowl apperture). If you up grade the power significantly then I would suggest 1' right thrust. I hope you enjoy building and flying her, I have and still do. Lindsay Quote Link to comment Share on other sites More sharing options...
Tony Cooper Posted January 29, 2009 Author Share Posted January 29, 2009 Thank you. I am just cutting out ribs and formers at the moment. I will post as I make progress Quote Link to comment Share on other sites More sharing options...
Terence Lynock Posted February 1, 2009 Share Posted February 1, 2009 Hi Folks, almost got the basic fuse built or at least it is 3-dimensional now, have all the wing ribs cut but then came to a standstill on it while I build a slow-flyer to play with in the garden but at present would have to dodge snow storms. I have decided to join the local model flying club so although I can fly Kamikazi-style, I will need to be far more gentlemanly and do it proper-like wot they do so built a high wing trainer which had a S400 plus 2.33/1 gearbox but I have just gutted it and fitted a Turnigy 2830 brushless which should help it perform a bit better. The Zulu E will follow on as a low wing trainer fitted with a Turnigy TR 35-42D 1000kv outrunner which should supply enough poke, weight of the motor is 132g so can you see any problems with this Lindsey or should I fit something a little more benign?, regards, Terry Quote Link to comment Share on other sites More sharing options...
Lindsay Todd Posted February 2, 2009 Share Posted February 2, 2009 Hi Terry, I'm not familiar with the motor, but as they say the throttle goes both ways, the model will certainly handle it. Have fun! Lindsay Quote Link to comment Share on other sites More sharing options...
Fats Flyer Posted February 10, 2009 Share Posted February 10, 2009 Ha Ha.........well done Lindsay, at last ......i can use up alot of my 6mm balsa i have in stock. This is my type of plan,quick list of wood and a blinder to build,this will appeal to alot of new builders,straight chord wing ,not too many parts and a good plan thats easy to read. Nice one Lindsay, what have you got on the building board for us all next ?...... vince Quote Link to comment Share on other sites More sharing options...
Fats Flyer Posted February 10, 2009 Share Posted February 10, 2009 Terry, That's the same motor that i'm putting in my Zulu-E. You'll have no problems there mate, plenty of power to have fun with. Vince Quote Link to comment Share on other sites More sharing options...
Lindsay Todd Posted February 10, 2009 Share Posted February 10, 2009 Vinnie, well the next one is a little more complex, a 60" Grumman Goose for twin electric, project now well on the way so look out for more details in the future. Glad you like the Zulu, have fun. Lindsay Quote Link to comment Share on other sites More sharing options...
Reuben Kinghorn Posted February 11, 2009 Share Posted February 11, 2009 Hey Guys, How about some photo's I'm still waiting on my Feb's copy, it's a couple of months behind on this side of the world -Reuben Quote Link to comment Share on other sites More sharing options...
David Ashby - Moderator Posted February 11, 2009 Share Posted February 11, 2009 Here you go Reuben, cute isn't she? Quote Link to comment Share on other sites More sharing options...
Reuben Kinghorn Posted February 11, 2009 Share Posted February 11, 2009 David, Thanks, I will take your advice and build this one next..... well next after my next stick build I've ordered a lasercut kit from the states, but the zulu is looking like the next one in line after that. -Reuben Quote Link to comment Share on other sites More sharing options...
magicstick Posted February 14, 2009 Share Posted February 14, 2009 hi everyone decided that the zulu will be my next build. i've some questions though. im not really into electric more i.c so is anyone converting it this way ? is it possible to convert this way ? on the rudder there is a cut out sort of nearly half circle is this right and is this for the elevator to allow movement ? i only ask as this is only my seconed ever experiance of building ? Quote Link to comment Share on other sites More sharing options...
Lindsay Todd Posted February 14, 2009 Share Posted February 14, 2009 Hi Magic stick, converting to ic will basically mean you need to move the front blukhead back to allow space for the engine mount, just make sure you keep it square, you may find you need to add a degree or so of right thrust. In addition you will not need the battery box area as this will make space for the fuel tank. The segment in the rudder is to give elevator clearance as you suggest. I would suggest an ic engine around the 0.25 to 0.30 would provide ample power. Lindsay Quote Link to comment Share on other sites More sharing options...
Foamie Dave Posted February 14, 2009 Share Posted February 14, 2009 Hi Lindsay, Great meeting you today. I knew I recognised the name but couldnt place you until the Zulu connection then it all clicked. (Im always a bit slow on the uptake). Just converting todays vids as we speak, so hopefully get some of the zebra striped wonder next time ! PS dont forget Foamie Dave when yer lotta comes up mate ..!! Quote Link to comment Share on other sites More sharing options...
Lindsay Todd Posted February 15, 2009 Share Posted February 15, 2009 Nice to meet you to Dave, I'll make sure we save some room in the Winnebago. Remember yours friends if luck comes your way, I expect a return of favour!! cheers Linds. Quote Link to comment Share on other sites More sharing options...
Tony Cooper Posted February 16, 2009 Author Share Posted February 16, 2009 Hi Lindsay I am at the moment building the fus, laying down the top(roof) of the latice on to the plan, I was going to use F4 as a spacer at the tail end but it seems to be too big, the 6mm outer longrons end up just 8mm from the 6x12mm "keel" the drawing of F4 shows it at 13mm .Have I gone wrong somewhere or just missreading the drawing? regards Tony Quote Link to comment Share on other sites More sharing options...
Lindsay Todd Posted February 16, 2009 Share Posted February 16, 2009 Hi Tony Your Correct! there does appear to be an error on this dimension which make F4 outer longeron positions wrong. But Don't Panic! The height of F4 is correct as is the base width. The 6mm outer longerons of the roof should be inset of those on the plan for F4. Basically if you use the internal vertical line of the longeron as the external line and draw a second line 6mm inboard of this you should find the position is then correct. The outer angle can then be adjusted to the external of the longeron. Do this to both sides. I hope that makes it clear. well done you check these things in the hope you catch any errors clearly that slipped through the net, sorry. Lindsay Quote Link to comment Share on other sites More sharing options...
Terence Lynock Posted February 19, 2009 Share Posted February 19, 2009 Your Correct! there does appear to be an error on this dimension which make F4 outer longeron positions wrong. You wanna know something Lindsey? I have the fuse built and didnt even notice that, it has all gone together quite happily and looks good, probably down to the years working at BSA Motorcycles in the 60's where,if something didnt fit, you made it fit......... regards, Terry Quote Link to comment Share on other sites More sharing options...
Lindsay Todd Posted February 19, 2009 Share Posted February 19, 2009 Cheers Terry, Glad the build is going well Lindsay Quote Link to comment Share on other sites More sharing options...
Fats Flyer Posted February 19, 2009 Share Posted February 19, 2009 Zulu Nearly Built now, made a couple of changes though,nothing to do with the design Lindsay,Honest .......i fixed a motor mount plate to the front of the plane because of the motor i had and made the battery plate on a sliding system so i could remove the motor with plenty of room and brilliant for the exact CofG. Lindsay,did you have any problems with the rudder at the bottom where the elevator cutout is regarding strength.....i found it to be a bit on the weak side and reinforced the bottom of the rudder with a little length of 6mm hard balsa running cross grain to make it more stable and less flexable. Im building this one for my daughter who loved the way the plane looked,but she wants me to do the livery colour scheme of the lion king ......i think she could be right for a fabalous look,i'll post piccies soon. Roll on the Grumman Goose,Will it be a plan feature for later in the year Lindsay? vince Quote Link to comment Share on other sites More sharing options...
Lindsay Todd Posted February 20, 2009 Share Posted February 20, 2009 Hi Vinnie, can't wait to see the pictures. Just had a look at the plan re the tail wheel, see what you mean, on the original the tail wheel wire extended above the rudder elevator cut out and was sandwiched in place by the rudder control horn. Not sure why there is a change here, maybe something in translation. Add some 1/64 ply as a stiffener if you suspect a problem with strength. As for the Grumman Goose, it appears RCM&E are keen to take the design, so fingers crossed. I am drafting the plan as I proceed, going well so far and should be ready by Easter with a bit of luck. Quote Link to comment Share on other sites More sharing options...
Phil Winks Posted February 21, 2009 Share Posted February 21, 2009 Roll on the Goose lindsay I can remember watching them take off from southampton water when I was much younger with any luck I'll have cleared my building board for the Zuu by then. Cant wait to see Vinnie's pics that sounds like an interesting colour scheme Quote Link to comment Share on other sites More sharing options...
magicstick Posted February 22, 2009 Share Posted February 22, 2009 lindsay, hi. can you explain to me why there is a tab on the front of the wing ribs ? was making a ply template for the ribs and cant work out why its there ? thanks Quote Link to comment Share on other sites More sharing options...
Lindsay Todd Posted February 22, 2009 Share Posted February 22, 2009 Hi magicstick, The tab is a simple means to ensure the wing ribs sit square to the building board during construction. They are then removed once initial construction is complete and you are ready to sheet the underside of the wing. Its quite common practice and a good way of preventing unwanted warps etc. Lindsay Quote Link to comment Share on other sites More sharing options...
Fats Flyer Posted February 28, 2009 Share Posted February 28, 2009 Hi Everyone , Well, iv'e completed the building side of the project and will start to cover this evening. I have put a servo in each wing for the ailerons and put some 9g 2KG micro servo's on the rear for the rudder and elevator.These little servo's are very good,if anyone wants these powerful little servo's ,i got them from BRC hobbies for £14.99 for four of them plus p&p,happy days eh?. Iv'e also changed the front nose end mainly because of the motor i had,i fixed a ply mount to the front,i think it looks rather good. Iv'e had a quick weight check and it looks like it will be approx 2 3/4 pounds A.U.W.......not bad eh ?. I hope you like the couple of piccies here. Quote Link to comment Share on other sites More sharing options...
