john kirkham Posted February 25, 2009 Share Posted February 25, 2009 hi all, new to this, this is my first aerobatic model just wandering how to put the servo's in to the wings. i have already run two seperate wires with plugs through the wings and both servo's move the same way for example, both aileron's go up and down together can anybody help!!!!!!!!!!!!!! Quote Link to comment Share on other sites More sharing options...
Snorbitz Posted February 25, 2009 Share Posted February 25, 2009 Somewhere in your transmitter set up there will be a SERVO REVERSE feature, It all depends on what make Tranny you have?. Sometimes they have switches in the back to reverse each individual one. Quote Link to comment Share on other sites More sharing options...
Martin Harris - Moderator Posted February 25, 2009 Share Posted February 25, 2009 This isn't usually a problem as the servo positions/arms usually mirror each other, giving opposite movement. If you're using a Y lead and have a radio that can mix 2 channels, why not use separate channels for each aileron - then you can reverse them, if necessary, on all but the oldest radios. Also, you'd get the benefit of being able to fine tune the roll axiality (if there's such a word!) using differential. Last resort would be to buy an add-on servo reverser. Quote Link to comment Share on other sites More sharing options...
john kirkham Posted February 25, 2009 Author Share Posted February 25, 2009 thanks Quote Link to comment Share on other sites More sharing options...
