Ronnie Mason Posted May 2, 2009 Share Posted May 2, 2009 Hello Peter, I have built your beautiful Mustang but I am having trouble with having to put in huge amounts of right trim. Your plans made no mention of side or down thrust. I am running an ASP 52 fs and I would be grateful if you could let me know if you can remember if any side trhrust was used in your prototype and if so how much? thanks. Ronnie Mason Quote Link to comment Share on other sites More sharing options...
Peter 'Ivanna Crashalot' Savage Posted May 15, 2009 Share Posted May 15, 2009 Peter Miller never uses any side or down thrust on his other models, i would assume it would be the same with this one. Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted May 15, 2009 Share Posted May 15, 2009 I never use side or down thrust on my aerobatic models. The engine that you are using is considerably more powerful than I did, that could be part of the problem, I am assuming that everything else is dead true. I normally find that if I need lots of trim, something isn't quite straight. The only models that have needed side or down thrust are the vintage high wing cabin models. Quote Link to comment Share on other sites More sharing options...
