Peter Webster Posted July 27, 2009 Share Posted July 27, 2009 Hi Stephen, The engine does not have any down thrust allowance but there is 2 degrees right. As viewed from the front the engine is shown rotated 15 degrees from horizontal. That is in an approx 10 O clock position. The rotation is about the horizontal / vertical line. The vertical being in the centre and horizontal 76mm above the bottom of the fire wall. I hope this helps. Peter Quote Link to comment Share on other sites More sharing options...
Stephen Jones Posted July 27, 2009 Author Share Posted July 27, 2009 Hi peter ,Thanks for the reply any chance of a picture of the front end of your model , as it looks like my engine is on the large side and the cowl is a bodjed job and i`ll have to make my own or do with out . P.S i added the center lines horizontal line 76mm from bottom cheers steve Edited By Stephen Jones on 27/07/2009 23:20:17 Quote Link to comment Share on other sites More sharing options...
Peter Webster Posted July 28, 2009 Share Posted July 28, 2009 Hi Stephen, hope this helps Quote Link to comment Share on other sites More sharing options...
Stephen Jones Posted July 29, 2009 Author Share Posted July 29, 2009 Yes thanks very much , 15* of horizontal and i can see by the diagram it is explanatory as to why the engine looks so big , the cowl is wrong and i will have to make some thing .And once again thanks very much for you're help .Hopefully i will be able to get it in the air weekend. Quote Link to comment Share on other sites More sharing options...
Peter Webster Posted July 29, 2009 Share Posted July 29, 2009 Hi Stephen, If you need a new cowl the company Carbon Copy produce a good range. Their Galaxy Domino cowl will fit and is very close in design. It is slightly different on the bottom but it is of no importance. Follow the link. http://www.carboncopyuk.com/acatalog/Galaxy_Models.html Quote Link to comment Share on other sites More sharing options...
Stephen Jones Posted July 30, 2009 Author Share Posted July 30, 2009 Hi peter,Those cowls seem a bit expensive to me , i`ll see how she flies , then i may make my own .thanks for the replay though . steve, Quote Link to comment Share on other sites More sharing options...
Rod Beasley Posted August 5, 2009 Share Posted August 5, 2009 Ok it is NOT a super tiger, It is a WOTS WOT biplane and i recognise it as having owned one myself. Easy to fly but a pain for setting the c of g. The downward pitch for this plane is 2-4 degrees off the horrizontal. the Cof G point was 1/3 in from the leading edge of the top wing on my model. Depending on the builder it should be the same on this example. This also looks very much like my old plane that I sold last year to a guy in Gloucester. If so then the C of G point stands. I stuck a 61 engine in it with a 16 x 6 prop and boy did it go. Sold it due to having too many models. Hope this helps with the I>D of the model. Quote Link to comment Share on other sites More sharing options...
Bob Cotsford Posted August 5, 2009 Share Posted August 5, 2009 funny looking WotsWot Quote Link to comment Share on other sites More sharing options...
simon barr Posted August 5, 2009 Share Posted August 5, 2009 No way is it a Wots Wot ! Wrong wing layout, wrong rear decking and wrong tail shape... Quote Link to comment Share on other sites More sharing options...
Stephen Jones Posted August 5, 2009 Author Share Posted August 5, 2009 I will provide more info , wing span ,fusalage length ectra tomorrow as it is a bit late nowEdited By Stephen Jones on 05/08/2009 23:54:29 Quote Link to comment Share on other sites More sharing options...
Stephen Jones Posted August 6, 2009 Author Share Posted August 6, 2009 Hi again, Hopefully the measurements i have taken will make identification more positive .Top wing span = 4` 10"bottom wing span = 3` 11"tail plane = 2` 2"fuselage = 3` 3" from fire wall to rear not including rudder. wings are of built up construction , fin and rudder from solid sheet.fuselage made from sheet sides and bottom , top seems to be ABS plastic . i am sure peter is right as the diagram of the front engine mounting shows the fire wall and fuselage sides edges which seem to be the same , and the fire wall is approx 120mm in hight . Quote Link to comment Share on other sites More sharing options...
Peter Webster Posted August 7, 2009 Share Posted August 7, 2009 Hi Stephen, these are my dims' Top wing 4'101/2" Bottom wing straight across 3'7" Tail 2'2" Fuselage 3'3" The construction is as you describe. Quote Link to comment Share on other sites More sharing options...
Stephen Jones Posted August 7, 2009 Author Share Posted August 7, 2009 Thanks peter, There's no doubt it's a Super Tiger , thaks to your picture and dimensions . I had to reinforce the fire wall on mine and the fuel proofer is drying as we speak . Hoping to get the radio gear in it tonight and fly it tomorrow . Also hopefully getting two other models ready , a Thing with a OS.25 sf and a Acrowot with RCV .61sp which I also had to reinforce the fire wall . Quote Link to comment Share on other sites More sharing options...
