Cezary Parmonik Posted August 5, 2009 Share Posted August 5, 2009 Finally manages to maiden my breeze. What a surpsise !!!! Easy to fly, great for beginner, as well as experienced pilot with more powerful setup. Great allrounder, quick to build. Problems with CoG ? No problem. Pretty forgiving when trying different positions. I used 4x HXT900 ( 9g servos), and fuselage could be a bit wider to fit them inside. Quote Link to comment Share on other sites More sharing options...
Cezary Parmonik Posted August 5, 2009 Author Share Posted August 5, 2009 A bit too much throttle, as i wasn`t sure about power. Needs few holes at the front of fuselage, as my Turnigy Plush 18A esc was hot on APC 7x4 and 1000mah 3S battery Edited By Cezary Parmonik on 05/08/2009 22:42:16Edited By Cezary Parmonik on 05/08/2009 22:45:45 Quote Link to comment Share on other sites More sharing options...
Cezary Parmonik Posted August 5, 2009 Author Share Posted August 5, 2009 And my Hyperion Yak 55 profile waiting for maiden flight Quote Link to comment Share on other sites More sharing options...
Bryce Allcorn - BritFlight.co.uk Posted August 6, 2009 Share Posted August 6, 2009 Cezary, You really don't hang about do you!? Only arrived on Monday this week! Great video, great flying - goes well with the 2812 and 3S LiPo, I'll do some tests and work out the power/current draw. If like the 2822 (1500KV - which is similar) we get about 120W @ 11amps using a 7x6E prop although don't suffer from the heat so much due to a slightly larger ESC. A couple of holes at the base of the cockpit "window" will give a fair amount of cooling flow. In standard 2S trim with the 2805 motor you will see 70W @ 8.5A with a 6x4E prop and 99W @ 12A with a 7x4E prop (APC types). Interesting method of mounting the servos, seems to work well though! Cheers, Bryce. Quote Link to comment Share on other sites More sharing options...
Cezary Parmonik Posted August 6, 2009 Author Share Posted August 6, 2009 Sweet plane. i love it !!!!. Pretty fast on full throttle, glides very well, and you can slow it right down for landing. If it`s about servos - if they`re damaged or stripped, no problem to swap them. They`re fit to fuselage with double sided tape. Fuselage could be a bit wider, so it would be easier to fit them inside. Doesn`t look quite neat, but works for me. Today i received Emax 2822 from BrcHobbies ( great serviceagain ), so i may try it. Overall - i`m happy with Breeze. I think it`s great allrounder. I`m thinking about Hustle )))) Or maybe H-Two-O ,to try take-offs and landings on water. Quote Link to comment Share on other sites More sharing options...
Cezary Parmonik Posted January 4, 2010 Author Share Posted January 4, 2010 After many enjoyable flights, and couple of crashes, it was time to "rebuild" my Breeze. Short visit at www.britflight.co.uk , and main fuselage ( blue by mistake, as my Breeze is red ) was on the way to join the rest. This time i decided to build it like "proper" modeller. The tail looks much better, took a bit to fit 2 x HXT900 inside, but worth the effort. Now need to buy couple of APC 7x4 and 7x5 propellers and "maiden" her again. CANNOT WAIT Edited By Cezary Parmonik on 04/01/2010 22:39:56 Quote Link to comment Share on other sites More sharing options...
EGB 953 Posted December 30, 2010 Share Posted December 30, 2010 Cezary if you are still around for an update on your Breeze I would be keen to hear it. Just got myself one for Xmas and witing for the weather to fly it. have found a couple of references to the 2822 motor mount issues with the grub screw coming loose - your experience? Cheers Quote Link to comment Share on other sites More sharing options...
Cezary Parmonik Posted January 9, 2011 Author Share Posted January 9, 2011 From my experience it`s common problem with e-max motors. A bit of thread lock helps. SInce my last post i changed motor for this. i`m using it with 7x4 up to 7x6 prop, and 25A turnigy plush esc, and 4 x HXT900 servos. Batteries from 1000 3S up to 1600 3S. Made some cooling holes with soldering iron on both sides of the fuz. Helps to cool things down. Lots of power when needed, and even with 1000 3S plenty of time in the air. One of my favourites planes so far Quote Link to comment Share on other sites More sharing options...
Chris Arnold 1 Posted January 19, 2011 Share Posted January 19, 2011 Ref the emax motors and their grub screws: I had one event where I had threadlocked the supplied allen key type grub but needed to undo it to swap a burnt out motor at my flying field without having to faff around also swapping the mount itself; I somehow managed to burr the inner allen key surfaces resukting in a "trapped" motor!! But mostly the grubs do work themselves loose regardless of threadlock, unless you go really OTT with it then end up with my burring problem Someone on the giantcod cf2822 page http://www.giantcod.co.uk/fc2822-1220kv-brushless-outrunner-motor-p-53.html suggested replacing the grubs with M3 bolts instead. I have done this and it works - you can really go OTT with threadlock while still having the reassurance that you can impart much more torque both tightening and undoing than with the allen grub, AND you also have a backup option that should you burr the screwdriver slot, pliers will almost certainly break the threadlock and all you then need to replace is the bolt itself. Its not the prettiest assembly - 2 bolts sticking out make it look Frankensteinesque - but at height, who's going to see them anyway??? And if you tolerate the bolts sticking out of a propsaver, whats the difference? Edited By Chris Arnold 1 on 19/01/2011 22:22:27Edited By Chris Arnold 1 on 19/01/2011 22:23:53 Quote Link to comment Share on other sites More sharing options...
EGB 953 Posted January 22, 2011 Share Posted January 22, 2011 That sounds a good solution. Can you get them from giantcod? Cezary, thanks for the update. My breeze flies very well so far (not much chance to fly it in London at the moment though) Cheers Edward Quote Link to comment Share on other sites More sharing options...
Chris Arnold 1 Posted January 23, 2011 Share Posted January 23, 2011 Get them from anywhere - I got mine from a local Maplin: http://www.maplin.co.uk/180-piece-screw-and-nut-set-44480 or ebay http://cgi.ebay.co.uk/M3-x10-A2-Stainless-Socket-Cap-Allen-Head-BOLTS-20-/400163724471?pt=UK_DIY_Material_Nails_Fixing_MJ&hash=item5d2b9ddcb7 or any non-"shed" hardware store Bit of a blurry mobile phone camera - no macro function!!! - shot of the motor with bolts: Quote Link to comment Share on other sites More sharing options...
