Mowerman Posted October 4, 2009 Share Posted October 4, 2009 Fellow club member has a Flair Bristol Fighter can anyone suggest rudder/aileron mix for this model? Quote Link to comment Share on other sites More sharing options...
simon barr Posted October 4, 2009 Share Posted October 4, 2009 I would suggest it would be better to learn to fly co-ordinated turns with seperate aileron and rudder...much better than mixing them in my opinion, and far more satisfying. Instigate the turn with rudder and aileron with the usual bit of back stick, then ease off the aileron and continue the turn with rudder and elevator...just as you would with full-size. Quote Link to comment Share on other sites More sharing options...
David Ashby - Moderator Posted October 4, 2009 Share Posted October 4, 2009 But start with say 5-10% and adjust +/- afterwards, you could have the mix on a switch so you can fly 'manual' as Simon says but with the option of flicking in the mix. Quote Link to comment Share on other sites More sharing options...
Former Member Posted October 4, 2009 Share Posted October 4, 2009 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Mowerman Posted October 5, 2009 Author Share Posted October 5, 2009 Thanks, I'll pass the info on. Simon, I thought that was why we bought computer radios, a bit like buying cars with synchromesh gears so we didnt have to double de-clutch to change gear Quote Link to comment Share on other sites More sharing options...
Frank Skilbeck Posted October 5, 2009 Share Posted October 5, 2009 Posted by Eric Bray on 04/10/2009 20:46:04:With coupled aileron/rudder, you cannot perform a proper side-slip approach, either. It's not so critical with an old bipe, but a Spit, Hurri or Mustang, etc, came in sideways so the pilot could see where he was going! Eric, depends on the radio but on my Sx the rudder stick is still active when CAR mode is on, so you can apply opposite rudder, you just need to move the stick a bit further. I think this was true of my old Fleet PCM set, so I would think this is true of most modern sets. Quote Link to comment Share on other sites More sharing options...
Evan Pimm Posted January 23, 2010 Share Posted January 23, 2010 My old JR radios are the same Frank, soon as you touch the rudder stick, with the mix switched on, you have independent rudder control. So no trouble at all for the 'cross control' situation. Spits and Hurris didn't come in 'slipped' Eric, ask the pilots and they'll tell you 'always off a curved approach'.Evan. Quote Link to comment Share on other sites More sharing options...
Former Member Posted January 23, 2010 Share Posted January 23, 2010 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
