Shaun K Posted July 12, 2007 Share Posted July 12, 2007 I'm looking for advice on placement of Solartrim lettering onto a Solarfilm covered fuselage. I'm just about finished on my first plan build (RCME Miss Lizzy plan) and have only got some lettering to go.The instruction sheet for Solartrim says to immerse the letter in water with a few drops of detergent and peel the backing off while under water. My first attempt with this failed dismally because the paper backing soaked through and wouldn't peel off cleanly. I also had trouble floating the letter into place. Despite wetting the surface and a cutting out a new letter, it just stuck in place right away.Can anyone offer advice on the right way to float Solartrim into place? How long do you soak for and how wet does the surface need to be?Thanks,Shaun K, Newcastle, Australia. Quote Link to comment Share on other sites More sharing options...
Mike Bell Posted July 12, 2007 Share Posted July 12, 2007 Shaun,You need both the adhesive surface of the trim and the surface of the film you are going to attach it to covered in water. Don't worry about over doing it as the aim is to have a film of water between the two surfaces until you are satisfied with the position. Once you are happy a firm press down on the letter will disperse the water and let the adhesive do it's stuff. Don't put too much detergent in though as this can interfere with the bond. Once pressed into place mop up with kitchen towel. Quote Link to comment Share on other sites More sharing options...
Grant Darnley Posted July 12, 2007 Share Posted July 12, 2007 And remember to use the credit card to squeegee out the air bubbles, they spoil all that hard work as my latest efforts prove Quote Link to comment Share on other sites More sharing options...
Chris Dickens Posted July 13, 2007 Share Posted July 13, 2007 Also, when the water has dried out (24hrs in a dry room) go over with a covering iron to ensure the edges are sealed and well stuck down. Quote Link to comment Share on other sites More sharing options...
Dead-stick Posted July 13, 2007 Share Posted July 13, 2007 The wife's indoor plant liquid spray bottle is an ideal tool for administering the water, if you dare to use it! If not, then Wilko's have them for less than a quid. Quote Link to comment Share on other sites More sharing options...
Shaun K Posted July 13, 2007 Author Share Posted July 13, 2007 Thanks for all your feedback guys!Much appreciated. Will see how it goes again tonight. Quote Link to comment Share on other sites More sharing options...
Shaun K Posted July 15, 2007 Author Share Posted July 15, 2007 Thanks again to all - used all the above advice and very happy with the results. Quote Link to comment Share on other sites More sharing options...
