Simon Turner Posted November 16, 2009 Share Posted November 16, 2009 OK, I've just tested my electric setup using my new 6EX and i had an issue setting my ESC, it just beeped a couple of times and didn't follow the expected setup routine (throttle up, beep twice etc) After a bit of fiddling I realised that the throttle was reversed i.e. push stick down was full throttle, I checked the 6EX programme for channel 3 and it was set to normal. A quick Google and I found quite a few articles stating that some ESC need the throttle reversing if using a Futaba. Has anyone come across this, is it an issue (I assume not as I programmed the TX to reverse channel 3 and bob's your mothers brother). i just want to see if this is a well known issue and make sure I won't run into another issue during a flight. SetUp: Futaba 6EX rx = Futaba R617FS ESC/BEC = GWES25A Thanks in advance Simon Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted November 16, 2009 Share Posted November 16, 2009 Its very common, if not universal for Futaba Tx to need throttle set to reverse ofr most ESCs or so I am led to belive - not a Fuby user m'self Quote Link to comment Share on other sites More sharing options...
Simon Turner Posted November 16, 2009 Author Share Posted November 16, 2009 Thanks Timbo, that's a relief (I thought I'd messed up all my shiny new gear ) Simon Quote Link to comment Share on other sites More sharing options...
Myron Beaumont Posted November 16, 2009 Share Posted November 16, 2009 Simon No probs. Yes- Just reverse channel 3 & carry on as normal , Quote Link to comment Share on other sites More sharing options...
Doug Ireland Posted November 17, 2009 Share Posted November 17, 2009 I forgot to re-bind after setting up the throttle on one of my models once, went to fully open on failsafe instead of closed. Could have been nasty! Quote Link to comment Share on other sites More sharing options...
Myron Beaumont Posted November 17, 2009 Share Posted November 17, 2009 Brings a whole new meaning to "failsafe" doesn't it Quote Link to comment Share on other sites More sharing options...
