Stephen Grigg Posted January 8, 2010 Share Posted January 8, 2010 A year ago I bought a GWS kit in the club Bring and buy.Unfortunately I was supplied with the incorrect paint and it had an adverse effect on the fuz and I gave up trying to repair it.As I had all the running gear Ive decided to use it on the Texan,and should be able to fly it with the snow.Its White.Ive bought the SG version only £25 ,I started it last evening S Ive done the ailerons,Glued the strengthening rods into the wings and glued the wings together.Ive also glued the fuselage together Quote Link to comment Share on other sites More sharing options...
ken anderson. Posted January 8, 2010 Share Posted January 8, 2010 yo stephen-i've got the GWS corsair...i'm on to my third version......great value model's............... ken anderson........... Quote Link to comment Share on other sites More sharing options...
Stephen Grigg Posted January 8, 2010 Author Share Posted January 8, 2010 Its amazing value as you say Ken and an interesting build compared to say a Seagull kit.I left everything to dry and although the fuselage is fine the wings were no.Ive left them on the top of the boiler only gets warm to cure before continuing.Wantt to ensure the provided glue is OK.Its a bit runny so maybe Im using to much and it needs longer to dry.Im not sure apart from there olwn what is safe to use.Any advice would be gratefully received.I thought Id some items missing but when I checked Galaxys Website nothing that was missing showed and they confirmed this,so I have to think out how to fit the power pack.I have an idea but any suggestions!!! Quote Link to comment Share on other sites More sharing options...
ken anderson. Posted January 9, 2010 Share Posted January 9, 2010 stephen-first time round i used the supplied glue-then after that i used 5 min epox...as for painting it you will have to get some of the foam friendly stuff..or acrylic or depending on what colour scheme---you can use ordinary emulsion... ken anderson........dont eat the yellow snow party ne 1. Quote Link to comment Share on other sites More sharing options...
Eck Posted January 9, 2010 Share Posted January 9, 2010 Hi Steven, I had the GWS Texan (painted as an RAAF Wirraway, a ground attack plane based on the NA-16) until my son piled it in for the last time last year. I also have two of the GWS FW 190s, which are fantastic, and the ME 109. The GWS glue is a total waste of time. As Ken said, 5-min epoxy is the way to go with these kits. The EPO versions are O.K. with cyano, but not the standard versions.For paint, I spray primed them all with CarPlan super acrylic spay primer, and finished off with Tamiya acrylic paints, either brushed or sprayed on, and a coat of B&Q satin acrylic varnish. I tend to make motor mounts these days from a stack of hard balsa discs, epoxied together, and to the firewall, and faced with 1/16" ply to take the screws for the motor radial mount. Quote Link to comment Share on other sites More sharing options...
Stephen Grigg Posted January 9, 2010 Author Share Posted January 9, 2010 Thanks for the advice Ive epoxy 5 min in stock,Im painting mine uuurh White with contrasting black stickers,Its a winter time camourflage.I checked the wings this morning and theyre fine now.Lots of tugging and everything stayed in place.The receivers arrived this morning,brilliant service from Brentford modelsEdited By Stephen Grigg on 09/01/2010 10:04:20 Quote Link to comment Share on other sites More sharing options...
Ben Mullins Posted January 9, 2010 Share Posted January 9, 2010 Heya Stephen, Try and get as much movement in the elevator as possible. I didn't, and now regret it! Also, the recommended C of G is too far back in my mind. When I flew the model on the stated C/G the thing was bouncing around the sky like a bucking bronco! All in all, a really nice model to fly! Quote Link to comment Share on other sites More sharing options...
Stephen Grigg Posted January 9, 2010 Author Share Posted January 9, 2010 Thanks for the help Ben that is invaluable advice much appreciated Quote Link to comment Share on other sites More sharing options...
Stephen Grigg Posted January 10, 2010 Author Share Posted January 10, 2010 Things went well last night especially now Im using 5 minute Epoxy,much quicker.Found a mount for the motor and fitted that and the nose cone Did the elevator hinges and glued the horizontal stabilizer in place then the rudder hinges and glued that in place.Then the canopy..Now I need your advice/. Are the decals stick on with a backing sheet? I spent ages trying to get the backing sheet off with no luck any tips pleaseFinally I fitted the prop and nose cone .It states in the instru7ctions to use the provided 2 sided adhasive tape to fit the servos ,have you found this is enough?.This is tonights job and the servo pushrodsEdited By Stephen Grigg on 10/01/2010 10:44:37 Quote Link to comment Share on other sites More sharing options...
ken anderson. Posted January 10, 2010 Share Posted January 10, 2010 yo stephen-the decals-you cut out off the sheet and peel off the backing----the double sided servo tape work's a treat as well-what i normally do is- be it on foam or wood- any spare 5 min epoxy you have left over smear it on the wood or foam -where you intend putting the servo-after it has dried out mount the servo - it'll stick like a goodin. anderson's model clinic ne 1.......... Quote Link to comment Share on other sites More sharing options...
Stephen Grigg Posted January 10, 2010 Author Share Posted January 10, 2010 Thanks Ken Ill have a go.Ive fitted the servos but cant get it to bind at the moment first it was there now its not,having a break.Ill go and have another wrestle with the decals Quote Link to comment Share on other sites More sharing options...
ken anderson. Posted January 10, 2010 Share Posted January 10, 2010 stephen-glad you got the post/answer...i tried earlier on -but the forum here is playing up.....out else give me a shout.....either on here or e-mail.......... ken anderson...... Quote Link to comment Share on other sites More sharing options...
Stephen Grigg Posted January 10, 2010 Author Share Posted January 10, 2010 Last nights work Quote Link to comment Share on other sites More sharing options...
Stephen Grigg Posted January 10, 2010 Author Share Posted January 10, 2010 Ive wrestled with the transfers and failed.,I b ound thr receiver but I think the battery has gon flat and the correct charging lead is in my car which is at work cos its useless in the snow so Ive given up for tonight.Ive fitted the servos but not glued them until Ive been able to check there centred Quote Link to comment Share on other sites More sharing options...
Stephen Grigg Posted January 11, 2010 Author Share Posted January 11, 2010 I think Ive discovered the problem with the decals .There the sort you get the backing off by putting them in water.Il do that tonight whilst waiting for the battery to charge Quote Link to comment Share on other sites More sharing options...
Andy Ramsay Posted January 11, 2010 Share Posted January 11, 2010 I painted mine in NZ airforce colours. A superb flyer but watch if you spin it. The wing on mine came away on the sixth turn. I reinforced the the area around the wing bolt with a very thin ply plate after glueing the rest of the bits together with my trusty hot glue gun. Like Ken I am on my third GWS Corsair. The second is still flying and with a terrific leap of imagination, and lots of hot glue, the first could probably also rise from the ashes. Another great kit and superb flyer. Hope the maiden flight goes well and positive you will enjoy it. Quote Link to comment Share on other sites More sharing options...
Stephen Grigg Posted January 12, 2010 Author Share Posted January 12, 2010 Thanks Andy Ive managed to get the hang of the Transfers and a bowl of water bit tricky they want to split but there are 2 big sheets and now need a biggercontainer to put them in.I also seem to have found the problemo with the receiver,I appear to have a duff one.It binds but then the light goes dim as if a flat battery.Tried another 1 and it now works a treat.So now Ive the servos centred and mecanically adjusted I can now glue them into position.Tomorrow that will be the first job followed by finishing the transfers Quote Link to comment Share on other sites More sharing options...
Stephen Grigg Posted January 12, 2010 Author Share Posted January 12, 2010 Ive now managed some how to break the nose cowl pooee Quote Link to comment Share on other sites More sharing options...
Stephen Grigg Posted January 12, 2010 Author Share Posted January 12, 2010 Apart fromj the demise of the cowl Ive finished th Texan.The Cof G seems ok a little on the nose heavy side,and as per Bens hint Iv plenty of elevator movement.The battery cover clip broke as soon as I tried it and Ive designed a new fixing using a rubber band!.Just a charge of the battery and Im ready Quote Link to comment Share on other sites More sharing options...
Eck Posted January 12, 2010 Share Posted January 12, 2010 The cowls fix easily with clear Sellotape,Stephen - Ask me how I know! They could do with a lot of rein forcement anyway, if you're going for hand launch/belly land. I use duct tape on the inside, sellotape on the outside. If all else fails, they cost about a fiver from your local Perkins dealer! ( I've just bought two for the Focke -Wulfs). Quote Link to comment Share on other sites More sharing options...
Stephen Grigg Posted January 13, 2010 Author Share Posted January 13, 2010 Thanks Eck 1 is on order Quote Link to comment Share on other sites More sharing options...
Kelly Posted January 13, 2010 Share Posted January 13, 2010 Hi My cowl split on the GWS 190, made it stronger by using strips of duct tape inside the cowl,no problems since . Quote Link to comment Share on other sites More sharing options...
Stephen Grigg Posted January 13, 2010 Author Share Posted January 13, 2010 Hi Kelvin did you get yto fly the Seagull Texan yet.Ive bought this one to practise on until the spring then Ill get the other one out again Quote Link to comment Share on other sites More sharing options...
Kelly Posted January 13, 2010 Share Posted January 13, 2010 Hi Stephen, No not yet, I removed the retracts and fitted larger wheels to the fixed U/C. Last time I tried to fly it the motor refused to run,fitted a new glow plug and checked the plumbing , waiting for the weather to pick up. I may try to make a temporary runway out of old strips of carpet . Decided to put the Boomer together with the taildragger mod, I know that will fly from my patch. The Seagull Dewoitina 520 is awaiting 8x servos and all the bits needed to put it together (lack of funds). The GWS Texan is looking good , I hand painted my 190 with acrylic paints after spraying a silver foam friendly base coat. Cheers Kelvin Quote Link to comment Share on other sites More sharing options...
Stephen Grigg Posted January 13, 2010 Author Share Posted January 13, 2010 Youve lots to look forward to then Kelvin,will it be a red carpet Quote Link to comment Share on other sites More sharing options...
