Hugh Coleman Posted January 12, 2010 Share Posted January 12, 2010 ... Just you try to install an aileron servo in the cavity supplied as indicated in the instructions and then try to fit the wing to the fuselage... The servo and the torque rods foul the throttle and tail feather servos. I ended up cutting a couple of holes in the bottom of each wing and installing two servos (one per wing) underneath. Aside from that and the fact that there is no indication of where the thrust line is, thus telling you where to bilt on your engine mount... I foolishly used the hole in the firewall as an indication and I reckon I have the engine 1/4" to 3/8" too low... The model as it comes out of the box is BEAUTIFUL... Now, to work out how to fit the bottom plate under the nose so that the undercart will be robust enough. Cheers, Hugh Quote Link to comment Share on other sites More sharing options...
Alan Cantwell Posted January 16, 2010 Share Posted January 16, 2010 do you have any pictures??? this is a model we keep getting mythered for, we have tried to drop it from the range from mod tech quite a few times, but it still seems to be immensly popular, never had this complaint, is it the yellow and white one? with the scollpoed trim, bit geebee ish??? Quote Link to comment Share on other sites More sharing options...
Hugh Coleman Posted January 17, 2010 Author Share Posted January 17, 2010 Hi, now mine is a very pleasing white and dark red. As I say, I cannot fault the quality otherwise... Maybe I just put the Servo tray in entirely the wrong place, but the instuctions were not clear on the loaction and where I did put it seemed to be logical... Mind you, I should have test fitted as well... You'd think I had learned at least that much from my static modelling experiences. Cheers, Hugh Quote Link to comment Share on other sites More sharing options...
Alan Cantwell Posted January 19, 2010 Share Posted January 19, 2010 it was changed and completely updated quite a while ago, now, provision is made for 2 aileron servos, what you have a is a very very early version, the new one is yellow and white, and is a very pretty affair, the kit you have bears no relation to our current lines how long have you had it? and if recent, where did you get it from? Quote Link to comment Share on other sites More sharing options...
Hugh Coleman Posted January 22, 2010 Author Share Posted January 22, 2010 I purchased it just before X-mas. A mob in Dandenong (Melbourne, Australia) who sourced it from Tates in Geelong. I was not aware that there had even been an update... If I had known, I would have demanded a knock down in the price. What other differences does the New Version have? Oh, And where is the thrust line supposed to be (not that it will make a difference now as I have already cut the cowel to fit the engine where it is). Cheers, Hugh Quote Link to comment Share on other sites More sharing options...
Hugh Coleman Posted January 22, 2010 Author Share Posted January 22, 2010 Here are some photos. The underside. I cut two cavities and reinforced the skin with a couple of strips of Spruce behind. I then dug away at the styrene core to create a tunnel for the servo cables. The upper side, showing the servo cables. Notide the left over stubs of the torque rods near the trailing edge where I have cut them off. Cheers, Hugh Quote Link to comment Share on other sites More sharing options...
Alan Cantwell Posted January 22, 2010 Share Posted January 22, 2010 Well, seeing as you are down under, it could have been lying on the shelf for a while, Mod-Tech have not produced a foam wing version of that model for years, and i MEAN years, the new one is built up wings, and i think, bigger, BUT, safe assured, it will fly well--they all do, hence why we keep getting asked for it!! your mod looks ok, bit long on the push rods, but it will be good Quote Link to comment Share on other sites More sharing options...
Alan Cantwell Posted January 22, 2010 Share Posted January 22, 2010 Quote Link to comment Share on other sites More sharing options...
Alan Cantwell Posted January 22, 2010 Share Posted January 22, 2010 thought there was a vid on our site of the DG flying, but sorry, all there is there are the instructions, but these will show you how the model has changed, wish i could find a shot of the top of the wing, the scheme is really nice Edited By ALAN C - YT Int'l on 22/01/2010 23:48:39Edited By ALAN C - YT Int'l on 22/01/2010 23:55:01 Quote Link to comment Share on other sites More sharing options...
Alan Cantwell Posted January 22, 2010 Share Posted January 22, 2010 best i could do http://www.ytinternational.co.uk/dragon_lady.htm Quote Link to comment Share on other sites More sharing options...
Alan Cantwell Posted January 22, 2010 Share Posted January 22, 2010 By the way, we have commisisioned a BIGGER version, for petrols, but gawd knows when it will get here--or even built, they have taken 4 years with our sea vixen, Quote Link to comment Share on other sites More sharing options...
Hugh Coleman Posted January 23, 2010 Author Share Posted January 23, 2010 That scheme is nice. I think I have seen photos of it somewhere. Mine is ready for its maiden now. I ran up the engine yesterday (it had had a rebuild after ending up buried up to the Muffler in a paddock). Everything seems ready to go. Cheers, Hugh Quote Link to comment Share on other sites More sharing options...
Hugh Coleman Posted January 30, 2010 Author Share Posted January 30, 2010 Maidened today. Had to move the battery pack back as far as I could get it, but aside from that, every thing was tickety boo. Flies very nicely. Cheers, Hugh Quote Link to comment Share on other sites More sharing options...
Hugh Coleman Posted May 15, 2010 Author Share Posted May 15, 2010 Well, I was in the local Hobby shop today, and I happened to see the up-sized version on the shelf. It will be on my must have list. In preperation, I impulse purchased an OS 55AX to hang off the front when I eventually do buy it. Don't tell the wife. Cheers, Hugh Quote Link to comment Share on other sites More sharing options...
Alan Cantwell Posted May 15, 2010 Share Posted May 15, 2010 Erm, its a 90-120 size 2 stroke plane, your 55 will not even taxi it well, click on the link i supplied above, it will take you straight to the site with all the info Quote Link to comment Share on other sites More sharing options...
Hugh Coleman Posted May 15, 2010 Author Share Posted May 15, 2010 Oh, yeah, right... Damn! Now what am I going to do with the 55AX? Cheers, Hugh Quote Link to comment Share on other sites More sharing options...
David Davis Posted May 16, 2010 Share Posted May 16, 2010 Take it back to the shop and trade it in for something bigger or keep it for a Senior Telemaster which I will willingly sell you!Edited By David Davis Telemaster Sales UK on 16/05/2010 07:20:54 Quote Link to comment Share on other sites More sharing options...
Hugh Coleman Posted May 17, 2010 Author Share Posted May 17, 2010 Actually, I think it can just stay in storage untill I am ready to tackle the Tony Nijhuis Hawker Typhoon. But that's a thread for another section... Cheers, Hugh Quote Link to comment Share on other sites More sharing options...
