inspector9566 Posted February 25, 2010 Share Posted February 25, 2010 I see requests for c of g help coming up alot I was given this link a long time ago and it works every time. also can we have this link put up somewhere as a sticky for all to see/use. please feel free to add any c of g settings you have for your planes to help others. Quote Link to comment Share on other sites More sharing options...
Allan Bowker Posted February 25, 2010 Share Posted February 25, 2010 An interesting link, thanks! Quote Link to comment Share on other sites More sharing options...
lan joseph Posted June 19, 2010 Share Posted June 19, 2010 Itezy online technical support:Good link. Enjoy your life in the Air. Quote Link to comment Share on other sites More sharing options...
Stephen Jones Posted June 19, 2010 Share Posted June 19, 2010 Very interesting now only if it could be done with biplanes and canards as well . Quote Link to comment Share on other sites More sharing options...
IanN Posted June 19, 2010 Share Posted June 19, 2010 I think I've seen that link on here before a while ago, but there wil be plenty who haven't so very worthwhile posting it again. This may also be of interest Quote Link to comment Share on other sites More sharing options...
Bundubasher Posted June 21, 2010 Share Posted June 21, 2010 I got a Weston Mini Tigershark - can someone recommend a safe CG setting for the maiden flight. Speed planes are not new to me, but this is fast and I don't want some nasty adrealine rush... Thanks Bundu Quote Link to comment Share on other sites More sharing options...
inspector9566 Posted June 21, 2010 Author Share Posted June 21, 2010 bundubasher if you click on the link in the first post at the top of this page you can put the measurements of any monoplane you have into this link and it will tell you the best c of g i have used it many times and it works great then you can fine tune it for your own style of flying. Quote Link to comment Share on other sites More sharing options...
Bundubasher Posted June 22, 2010 Share Posted June 22, 2010 Inspector9566. Thanks, I had a look at it and bookmarked it for my other planes. It looks excellent. The Weston Minitigershark is a hot delta and I'm looking at cg advice from people that have flown this delta. Quote Link to comment Share on other sites More sharing options...
Diamond Geezer Posted June 22, 2010 Share Posted June 22, 2010 Hi Inspector 9566 what is the static margin Quote Link to comment Share on other sites More sharing options...
inspector9566 Posted June 23, 2010 Author Share Posted June 23, 2010 Hi Diamond Geezer For an aircraft to be stable in pitch, its CG must be forward of the Neutral Point NP by a safety factor called the Static Margin, which is a percentage of the MAC (Mean Aerodynamic Chord). Static Margin should be between 5% and 15% for a good stability. I dont use this box I put in the measurements from the plane let the program do its thing and set the plane to this setting and then fine tune to my taste and flying style for that plane. hope this helps Quote Link to comment Share on other sites More sharing options...
Diamond Geezer Posted July 31, 2010 Share Posted July 31, 2010 Inspector9566 I've tried to do this put in the measurments of the plane without using the static margin box as suggested it wont work says ivalid static margin error put in between 5 and 15% help with this please Quote Link to comment Share on other sites More sharing options...
Stephen Jones Posted July 31, 2010 Share Posted July 31, 2010 Hi I have seen this link before but couldn't find how to make it work for a canard twin bipe . Quote Link to comment Share on other sites More sharing options...
inspector9566 Posted August 1, 2010 Author Share Posted August 1, 2010 Hi Diamond Geezer I cant help with your problem as I havent come across it when I have used this site but this is the home page for this site right at the bottom there is an email me box they might be better positioned to help you. hope you sort it as its a great little program. Stephen it might be worth an email to them to see if this program would do what you need it to do for you. I would be interested to see how you both get on.Edited By inspector9566 on 01/08/2010 21:33:09 Quote Link to comment Share on other sites More sharing options...
Diamond Geezer Posted August 2, 2010 Share Posted August 2, 2010 thx Quote Link to comment Share on other sites More sharing options...
The Giggler Posted August 12, 2010 Share Posted August 12, 2010 Sorry guy's N gals for this old dog. Im trying to work out the C o G of a plane, To start with I tried the link at the top of this thread,Spent a hour measureing and re-measuring!! And at 15%static margin it tells me the CoG is 139mm from the leading edge, If i use the way of adding the root of the wiing plus the tip of the wing then in my case its 320mm + 220mm = 540mm then devide by 2 = 270mm times by 0.333 = 89.91mm from the leading edge?? Get's worse, Use the 30% of the root in my case 320mm devide it by 3 = 106.6mm from the leading edge ?? If i lower the static margin then the CoG goes back even more. This is the plane i just bought it, Quote Link to comment Share on other sites More sharing options...
The Giggler Posted August 12, 2010 Share Posted August 12, 2010 photo link Edited By David Ashby - RCME Administrator on 12/08/2010 06:30:58 Quote Link to comment Share on other sites More sharing options...
Bruce Richards Posted August 12, 2010 Share Posted August 12, 2010 Stick it at 110mm and see how it flys would be my suggestion. Quote Link to comment Share on other sites More sharing options...
Anton M Posted August 12, 2010 Share Posted August 12, 2010 The Giggler: since your plane has a relatively long tail moment, the CG would be more aft than conventional. So, maybe the calculated CG is not far off. Quote Link to comment Share on other sites More sharing options...
Diamond Geezer Posted August 12, 2010 Share Posted August 12, 2010 Hi Giggler I woild use the old method being a 1/3rd of the wing chord or where the spar is about right but remember its best to be slightly nose heavy hope this helps Geoff Quote Link to comment Share on other sites More sharing options...
