Andy Freeman Posted February 27, 2010 Share Posted February 27, 2010 Bear with me here. I have made a hot wire bow and have a 200W power supply for it.I harbour aspirations of making my own combat wing and a "fish" type areobat for the slopes. This after noon i tried it out on some foam i had in the garage. Firstly white EPS foam that seems to have a low density, the wire goes through this like a politician through an expenses enquiry. Using some of the "brown foam i had which seems a lot denser, i could not cut very well at all. Either too fast giving a starving horse effect or too slow and melting great swathes of foam where foam there ought to be still. So, to the question. Does the pink/blue/white stuff from the builders yard cut with the wire to an decent standard like the white stuff i had? I believe that the blue stuff also sands well? If i go into the buiders merchant on Monday morning what do i need to ask for? Is there a particular brand? Density? a generic name even? Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted February 27, 2010 Share Posted February 27, 2010 The only generic term I know of is blue foam On the cutting - you dont say how much practice you have had, I can tell you it does take a lot before you get it right. The temperature of the wire has to be right too, is the PSU variable ? Edited By Timbo - Administrator on 27/02/2010 20:09:58 Quote Link to comment Share on other sites More sharing options...
Andy Freeman Posted February 27, 2010 Author Share Posted February 27, 2010 Timbo, the current and the Voltage can be twiddled to a max of 200W. i have had one other go of cutting and that was a tiny wing for an Limit ex. So small i could have used a sanding block I did manage to get something i would have been happy using from the white EPS although the block i have it is not dense enough for making a wing. I am happy to use EPS if i can get a recommended density to ask for. Quote Link to comment Share on other sites More sharing options...
Former Member Posted February 27, 2010 Share Posted February 27, 2010 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Myron Beaumont Posted February 27, 2010 Share Posted February 27, 2010 ???? Quote Link to comment Share on other sites More sharing options...
twinstar Posted February 27, 2010 Share Posted February 27, 2010 thers places on the internet where you can buy blue foam in useful sizes for modellers and if you want custom foam wingshttp://www.foamwings.co.uk/Pages/Site/Default.asp Quote Link to comment Share on other sites More sharing options...
r6dan Posted September 18, 2010 Share Posted September 18, 2010 There is a place called Shefffield insulation near me which I hear does that kind of stuff,I will pop in on monday and have a looky see as I want more foam too,if it does I can get you some... Quote Link to comment Share on other sites More sharing options...
