Cyrill Carr Aero L59 PSS Build
David Gilder
  • 2 years later...
well no i was supprised with a 3s 2200 it was spot on , this was my test version ,i would like a one thats a bit better ie influx better and a bit tidier it also needs a bigger edf or 4s this motor wont take 4s though. but experimenting is half the fun . i did make 1 tip tank out of laminated 1/4 sheet . i am busy building another free plan from years ago , a coachman trainer for my little lad to learn. when thats done i will get a better l59 done hopefully
As I'm planning to use this as a light wind ship, I will be covering with solar film.
Just need to choose the design as it needs to be a proper one for PSS!!!
Its going to have the intakes as it has to look correct, however, I am toying with the idea of making these from foam and veneering them! Time will tell!!
Dave
  • 1 month later...
Time for an update!
The fuselage has been completed and I have covered opt this evening in its base colour of white, ready for the scale colours to go on!
Wings are joined and wing bandage drying.
Tip tanks shaped and ready for covering prior to glueing onto the wings!
So, here's a pic of the fuselage tonight to give you a glimpse!
Will give you all an update as things progress!!
Dave
