cymaz Posted April 19, 2010 Share Posted April 19, 2010 Hi all Does anyone know where I could source a chipmunk canopy for a VMAR ?? It does not have to be VMAR but its for a 48" size Chip. Thanks Quote Link to comment Share on other sites More sharing options...
Olly P Posted April 19, 2010 Share Posted April 19, 2010 Peter, Have you tried VMAR themselves - I found it best to ring them as there email takes a while to reply, but they are usually quite helpful... Quote Link to comment Share on other sites More sharing options...
David Ashby - Moderator Posted April 19, 2010 Share Posted April 19, 2010 UK distributor is MacGregors so might be worth giving them a call - 01628 760430. Quote Link to comment Share on other sites More sharing options...
cymaz Posted April 20, 2010 Author Share Posted April 20, 2010 Cheers for the replies. Does VMAR have a dedicated phone number Olly P ??? Quote Link to comment Share on other sites More sharing options...
David Ashby - Moderator Posted April 20, 2010 Share Posted April 20, 2010 Peter, VMAR are a company based in Vietnam, no harm in trying I guess.... Have you contacted them direct then Olly? Quote Link to comment Share on other sites More sharing options...
Andy Palmer Posted May 26, 2010 Share Posted May 26, 2010 Can't help with a canopy but I am considering buying a VMAR Chipmunk for electric power. How do you rate the model? Thanks, Quote Link to comment Share on other sites More sharing options...
cymaz Posted May 28, 2010 Author Share Posted May 28, 2010 The vmar canopy was for a mate, I don't own one. I do own the Blackhorse Chip 60" model ( I couldn't face the wife if I had the 45cc size one) It fleis really well and no vices. Quote Link to comment Share on other sites More sharing options...
Andy Palmer Posted May 28, 2010 Share Posted May 28, 2010 That was brilliant timing, I have just ordered the Black Horse Chipmunk, I pick it up tomorrow morning. Having read the reports on the BH one I decided it was worth paying the extra money for one that everyone says it good, I found some pretty negative stuff about VMAR models in general. Quote Link to comment Share on other sites More sharing options...
cymaz Posted May 29, 2010 Author Share Posted May 29, 2010 I put a asp70 fs fully inverted....goes well and sounds really nice. Quote Link to comment Share on other sites More sharing options...
Andy Palmer Posted May 29, 2010 Share Posted May 29, 2010 That's good to hear Peter, I think my electric set-up is approx equivalent to a 70 fs. Just got back from the shop, I got the Chipmunk as planned but also got tempted by by a VQ CAP 10 and ended up buying that as well! Now which should I assemble first.... Quote Link to comment Share on other sites More sharing options...
cymaz Posted May 29, 2010 Author Share Posted May 29, 2010 TOSS A COIN!!!!!!!!!!!!!!!!!!!!!!! Quote Link to comment Share on other sites More sharing options...
Andy Palmer Posted May 29, 2010 Share Posted May 29, 2010 I've started... it's the CAP first. I don't think it will take long and then I will move on to the Chipmunk. They are both lovely models but I think the Chipmunk is probably higher quality. Quote Link to comment Share on other sites More sharing options...
cymaz Posted May 29, 2010 Author Share Posted May 29, 2010 Take your time with the belly pan and make sure it lines up with the fus, if need be put the wings on to give you a better idea. Quote Link to comment Share on other sites More sharing options...
Andy Palmer Posted May 30, 2010 Share Posted May 30, 2010 OK wil do. I read on another forum that the belly pan is not the easiest part to fit decently. Thanks. Quote Link to comment Share on other sites More sharing options...
cymaz Posted May 30, 2010 Author Share Posted May 30, 2010 And also where the cover fits over the tailwheel assembly in the rear of the fus,,,I screwed mine down instead of glueing it- just in case I should ever want to readjust the rudder and tail wheel assembly. Quote Link to comment Share on other sites More sharing options...
Andy Palmer Posted May 30, 2010 Share Posted May 30, 2010 OK, I will watch for that then. I expect you have read this thread: http://www.rcgroups.com/forums/showthread.php?t=739137 Lots of helpful stuff there. Do you know what the finished weight of yours is, and did you have any problems achieving the recommended CG position? Quote Link to comment Share on other sites More sharing options...
cymaz Posted May 31, 2010 Author Share Posted May 31, 2010 Er...never weighed mine but with the ASP I only had to add about 15-20g of nose ballast. Quote Link to comment Share on other sites More sharing options...
Andy Palmer Posted May 31, 2010 Share Posted May 31, 2010 That's quite encouraging, some people seem to have needed lots of lead in the nose. Quote Link to comment Share on other sites More sharing options...
cymaz Posted June 1, 2010 Author Share Posted June 1, 2010 I put the engine as far forward as poss, and ASP are not the lightest. Hope the pics do justice.... Quote Link to comment Share on other sites More sharing options...
Andy Palmer Posted June 2, 2010 Share Posted June 2, 2010 It looks as if I can get my batteries well forward so I think it should be fine and hopefully need little or no lead. Quote Link to comment Share on other sites More sharing options...
