jimmyboy Posted July 22, 2010 Share Posted July 22, 2010 Hi all, is it possible to connect a Futaba 6EXA 35mhz to a Futaba 2.4 Ghz via a buddy lead. If so can you explain please, Jim Quote Link to comment Share on other sites More sharing options...
simon barr Posted July 22, 2010 Share Posted July 22, 2010 Yes you can, I use a 35 mhz 6EXA as a buddy all the time. You will have to activate the buddy mode in the 2.4 set if this is being used as the master, and take the Xtal out of the 35 mhz set. Quote Link to comment Share on other sites More sharing options...
kc Posted July 23, 2010 Share Posted July 23, 2010 I think you can use any two Futaba sets if both have the latest type buddy lead socket, square not round.. See the Futaba website.Edited By kc on 23/07/2010 10:58:38 Quote Link to comment Share on other sites More sharing options...
Roger Adams Posted July 23, 2010 Share Posted July 23, 2010 When I last did this it worked OK but with a major caveat. There was a delay of about 1 -1.5 secs when transferring control to the student (35mhz). Taking control back to the master was instant. The technique was for the instructor to get the plane straight & level, press the training switch and pause before saying "you have control", this pause prevented the student putting in big control movements because of no response during the switch over. I can't remember for certain the exact radios, but it was probably a 6x?? 2.4 Ghz, and a 7CAP 35mhz. Quote Link to comment Share on other sites More sharing options...
Michael Hickman Posted July 23, 2010 Share Posted July 23, 2010 The 35 mhz Tx must be using PPM. Mike Quote Link to comment Share on other sites More sharing options...
jimmyboy Posted July 23, 2010 Author Share Posted July 23, 2010 Many thanks to all who responded about buddying up a 35 set to a 2.4 set. Jim Quote Link to comment Share on other sites More sharing options...
