David the flyer Posted August 25, 2010 Share Posted August 25, 2010 Hi I've got a spektrum dx6i, my plane has flaps, is the a programme where I can mix the flops with the elevator, ie When I activate e flaps I would like the elevator to add a little up to level the plane out? Or is that not a good thing to do? Cheers DaveEdited By David the flyer on 25/08/2010 21:29:18 Quote Link to comment Share on other sites More sharing options...
Hugh Coleman Posted August 25, 2010 Share Posted August 25, 2010 I'm pretty sure there is. Check the manual under "Flapperos" in the mixing section. Cheers, HughEdited By Hugh Coleman on 25/08/2010 23:23:56 Quote Link to comment Share on other sites More sharing options...
Frank Skilbeck Posted August 29, 2010 Share Posted August 29, 2010 Its quite simple, go to page 68 in the manual, in the adjust list go to flaps and you can set the elevator compensation for normal and land. Just a word of caution though each plane reacts differently to flaps, the ones I have tend to pitch up when flap is applied, so I have some down elevator mixed in for compensation. if its a new plane I would recommend that you reduce the flap travel initially and try out the flap at height to see how the plane reacts to flap, you can then adjust the flap travel and elevator compensation to get what you need. Quote Link to comment Share on other sites More sharing options...
David the flyer Posted August 29, 2010 Author Share Posted August 29, 2010 Thanks for the reply, I'm at the field tomorrow I will give that a go Cheers dave Quote Link to comment Share on other sites More sharing options...
Simon Reid Posted September 25, 2010 Share Posted September 25, 2010 Different subject. Ratchet on Throttle stick. Reading the October issue, an article by Alex Whittaker states that he fitted the supplied throttle stick ratchet. Mine never came with this, and there is no mention of it in the Instruction book. Am I missing something? Quote Link to comment Share on other sites More sharing options...
Tony Cooper Posted September 25, 2010 Share Posted September 25, 2010 Yes, mine came with a ratchet spring and an allen type key for the sticks. Edited By Tony Cooper on 25/09/2010 14:06:24 Quote Link to comment Share on other sites More sharing options...
Chris Bott - Moderator Posted September 25, 2010 Share Posted September 25, 2010 Simon mine came with no ratchet fittings, when I read about it I was a bit miffed too. I haven't tried, but as Horizon UK seem to be such a good distributor, try contacting them and see if they send you one out? Quote Link to comment Share on other sites More sharing options...
Pete B Posted September 25, 2010 Share Posted September 25, 2010 Bought mine a couple of years ago - no bits with it then. I use both a Dx6i and an Optic 6, one without and one with a ratchet and TBH don't find it a problem swapping between them. If anything, helis are better without the ratchet for fine throttle control. Pete Quote Link to comment Share on other sites More sharing options...
Tom T Posted October 9, 2011 Share Posted October 9, 2011 Sorry everyone, slightly off topic but does anyone have an unused or old USB lead (spektrum (dx6i) to computer lead for simulator) kicking about that I could buy off them? Would be much appreciated Many thanks Tom Quote Link to comment Share on other sites More sharing options...
Tom T Posted October 10, 2011 Share Posted October 10, 2011 Can a poor man ask for a Favor? LOL Any simulator leads selling? Tom Quote Link to comment Share on other sites More sharing options...
Pete B Posted October 10, 2011 Share Posted October 10, 2011 Addlestone Model Centre list a Phoenix Sim Spektrum Cable for just £2.99, Tom, if that's what you require. PeteEdited By Pete B on 10/10/2011 18:48:14 Quote Link to comment Share on other sites More sharing options...
Chris Bott - Moderator Posted October 10, 2011 Share Posted October 10, 2011 Pete I think that at £2.99 would adapt between the Spektrum Tx and a Phoenix cable. Tom, if you need a Spektrum to USB cable try something like this from the big fish. Quote Link to comment Share on other sites More sharing options...
Tom T Posted October 10, 2011 Share Posted October 10, 2011 Thanx alot I will order it Quote Link to comment Share on other sites More sharing options...
Tom T Posted November 12, 2011 Share Posted November 12, 2011 Hi, sorry to miss use this topic page again but please may i have some advise.... I have a spektrum dx6i transmitter (AR6200 receiver) and have been having a few issues with it. A few months back a member at the club that i am at flew my plane using the dx6i and it was all going well until he came for a landing.... the plane glitched for a split second pushing it upside down. Fortunately we had a lucky escape and he managed to recover it and land it. We thought we found out what the problem is..... we separated the receiver and the satellite(put them further away) and that seemed to work fine until today. I took the model fairly high up but not to high that it would be a signal loss and it then glitched again, although this time it pulled up vertical (all controls froze). Fortunately once again i managed to take control of the plane and land it safely. After the heart stopped racing :P we decided we would do a range check..... it was ok until it reached about 10 paces and then it started becoming very laggy. Does anyone have any suggestions on what I should do. Is it a fault with the receiver? Should i send it back? Or has there been a recall? Cheers Tom Quote Link to comment Share on other sites More sharing options...
Tom T Posted November 12, 2011 Share Posted November 12, 2011 Should i contact the people i brought it from?? Quote Link to comment Share on other sites More sharing options...
Hamish Posted November 12, 2011 Share Posted November 12, 2011 Tom I would have expected a range check at 30m plus and at 10 paces you appear to have problems. Send the Rx back to Horizon Hobbies, they will check and say no problems found but as a gesture will give you a brand new Rx FOC. Two glitches is two much when you can get this type of service.I stupidly lost 3 models until it dawned it was the Rx and the replacement has given no problems. I only wish HH would just say they had found a problem as it then eliminate one component in the chain.Edited By Hamish on 12/11/2011 22:16:23 Quote Link to comment Share on other sites More sharing options...
Hamish Posted November 12, 2011 Share Posted November 12, 2011 Sorry duplicate posting. Done on my iPad.Edited By Hamish on 12/11/2011 22:12:30 Quote Link to comment Share on other sites More sharing options...
Tom T Posted November 12, 2011 Share Posted November 12, 2011 Ok thanx I will do that ... Do you have a link for where i should be looking or is it just there general contact address? Cheers Tom Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted November 12, 2011 Share Posted November 12, 2011 Tom its Spektrum Service Centre Horizon Hobby UK Units 1 to 4 Ployters Road Staple Tye Southern Way Harlow Essex CM18 7NS Quote Link to comment Share on other sites More sharing options...
Tom T Posted November 12, 2011 Share Posted November 12, 2011 Ok Thanx So do i just package it all up and then stick a label on the front with that address with my address inside? Sorry to ask such an obvious question but i wanted to make sure... haha.. Sorry!! Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted November 13, 2011 Share Posted November 13, 2011 Yes. Quote Link to comment Share on other sites More sharing options...
GrahamC Posted November 14, 2011 Share Posted November 14, 2011 Tom, even if they send you a new receiver it might also be worth checking your receiver battery, and your switch harness. As for the battery, how does it perform under load? Spektrum receivers seem to have a reputation for 'browning out' if the voltage supply drops too much - say when all the servos are moving. If you don't have a load tester someone in your club might. Also just check your switch harness. I seem to remember reading on the forum that you have one receiver that has been in a number of planes. We recently had the switch harness on an aircraft fail where it had been plugged in and unplugged a number of times. Basically the wire just behind the plug that connects to the receiver was beginning to fail. If you wiggled it, the receiver would go on and off. We very nearly lost the aircraft but were fortunate. The plane flew a down-wind leg all by itself with the fail safe engaged and the throttle at idle. Fortunately it was well trimmed and very happy to continue its short free flight experience. It then turned itself back on! I immediately landed. Not something I would like to repeat!Closer inspection exonerated the receiver but identified the switch harness as the problem. Quote Link to comment Share on other sites More sharing options...
Tom T Posted November 14, 2011 Share Posted November 14, 2011 Hi Graham, I have tested it with a load tester and it was all fine the receiver that was in it was new to that plane and a new one altogether..... I think i'll end up sending it back to get it checked properly to be sure. hmm.... your near crash experience sounds a bit like what happened to me but I've checked the harness and seems fine... i'll send it off... Cheers Tom Quote Link to comment Share on other sites More sharing options...
