micarus Posted October 25, 2010 Share Posted October 25, 2010 Hi guys, Anyone out there building a 72 inch Spit' as I contacted Retracts International only to find out they are taking no more orders and will close down at the end of the year?? anyone used Giant Cod gear on a plane this size?? Any advice on alternatives? Cheers MIKE. Quote Link to comment Share on other sites More sharing options...
Ed Darter Posted October 26, 2010 Share Posted October 26, 2010 Do you mean they have gone out of business ? Thats not good news :-/ Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted October 26, 2010 Share Posted October 26, 2010 Hi Mike, there are three of us that I know of building the 70" TN Spit. Myself Tom Foreman and Herri. You will find the build blogs under the Tony Nijhuis section. I don't think Tom has a seperate blog yet and joins in with ours If you mean Unitracts International, I was speaking to Tony just before he went on holiday and he was telling me that he was going to wrap it up at the end of the year. A real pity but the economics didn't make much sense. Tony has seen big rises in his costs. A real pity as I have only started dealing with him in the last few years, and he is a very helpful and friendly guy. Cheers Danny Quote Link to comment Share on other sites More sharing options...
micarus Posted October 26, 2010 Author Share Posted October 26, 2010 THanks for the answer Danny, Yes I did mean" Unitracts" <Senior moment!> I was going to get retracts from them but looks like I will have to go elswhere, I am looking at Eflite electric ones as they look solid and do not require a separate servo, any thoughts? What are you guys using? What do you think of the wood pack etc'? I'm still costing up. Cheers MIKE. Quote Link to comment Share on other sites More sharing options...
Tom Foreman Posted October 26, 2010 Share Posted October 26, 2010 Hi Micarus, I'd recommend the wood pack it saves a few days of working out what you need and only saves £20 which is more like £10 once you factor in postage. Will have a think about alternative retracts, electric ones would be good, the trouble is will they be able to handle 15lb and will they do the angles and oleos required for a scale plane Tom Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted October 26, 2010 Share Posted October 26, 2010 Hi Mike, I am pleased with the wood pack in general. The cutting has been accurate, for both the Laser and the Routed birchply/liteply. I had a sheet of wood that I think was overly dried and it warped quicker than you could blink. I should really have cut another of those. But I kind of expect the odd hiccup along the way. There were also two areas where the laser hadn't cut all the way through, but that was easy to just run over with a sharp scalpel. The drawings show the fus sides as they are viewed from the side, and my laser parts have been cut to those dimensions. This is not strictly speaking correct, as when you curve the top and bend in the tail, the cut wood will need to be both longer and taller. Tony mentions this on the drawing, but my cut bits match my plan If you were building from the plan you haven't actually got an accurate outline. I would mention this in Herri's build (unless you are looking in Herri?) as herri has a set of drawings from Tony directly, I would be interested to see if the fus height and length are increased in the wood over the plan, or if the plan makes allowance for this. Anyway its stand off scale, it will be fine Cheers DannyEdited By Danny Fenton on 26/10/2010 16:02:36 Quote Link to comment Share on other sites More sharing options...
micarus Posted October 26, 2010 Author Share Posted October 26, 2010 Hi Danny ,sorry to be so thick, but how do I find Tony's section ? I 'v looked all over the forum and don't see it ,even put it in the search , but no luck. Cheers MIKE. Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted October 26, 2010 Share Posted October 26, 2010 Hi Mike if you go to the All Topics at the top of the page, then scroll down to the Workshop section, you will find Tony Nijhuis plan builders lurking there You will get used to where everything is eventually, then david and Timbo will move it all around again just to keep us on our toes Cheers Danny Quote Link to comment Share on other sites More sharing options...
micarus Posted October 26, 2010 Author Share Posted October 26, 2010 Thanks a lot Danny and for the info about the pack ! I think I will go ahead and order it ,I'v been building on and off since 73, so recon I can get past a few discrepacies. Look forward to reading the Build writeups <and the build> Just repairing the Storch < how can you prang one of those ? you may ask! doh!> Cheers MIKE. Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted October 26, 2010 Share Posted October 26, 2010 Posted by Danny Fenton on 26/10/2010 16:04:36:Hi Mike if you go to the All Topics at the top of the page, then scroll down to the Workshop section, you will find Tony Nijhuis plan builders lurking there You will get used to where everything is eventually, then david and Timbo will move it all around again just to keep us on our toes Cheers Danny And, as if by magic, I have just done exactly that with this thread Edited By Tim Mackey - Administrator on 26/10/2010 17:15:23 Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted October 26, 2010 Share Posted October 26, 2010 Can you also use some magic to correct the typo in Tony's name...... Edited By Danny Fenton on 26/10/2010 17:20:43 Quote Link to comment Share on other sites More sharing options...
