Lee Smalley Posted November 18, 2010 Share Posted November 18, 2010 26 would fly it nice BB 30 would give you ooodles of vertical performance but mybe too much ! Quote Link to comment Share on other sites More sharing options...
BB Posted November 18, 2010 Share Posted November 18, 2010 Thing is Lee I've got a 23cc swinging a 17x8 in a 68" 9.5Lb Wot 4. Vertical with that ain't a propblem. I think your right 30 might make things too interesting. BB Quote Link to comment Share on other sites More sharing options...
Ross Clarkson Posted November 18, 2010 Author Share Posted November 18, 2010 Lee is the man to speak to about that BB, as you have already discovered. I was thinking about petrol, but changed my mind purely because i havent ever had a four stroke yet, so i want to get to grips with FS's first.Otherwise, i think it would have been a 26cc on Lee's advice. I work nights too, but when i get up about this time, i have nothing else to do and she just calls me into the dining room!!! ha ha. Stephen: It is official, my engine has arrived and my dad teasingly showed me the box, but won't let me have it until Xmas even after much persuasion!!! Quote Link to comment Share on other sites More sharing options...
Lee Smalley Posted November 18, 2010 Share Posted November 18, 2010 Hi BB mine has a ASP 108, 18CC and mine has plenty of ooomph sometimes i do wish i had a bit more, it will prop hang but only just and i can't pull out of it or correct very easily but for now its enough ! Quote Link to comment Share on other sites More sharing options...
Lee Smalley Posted November 18, 2010 Share Posted November 18, 2010 my first Yak i swear it was a feather light touch down !! Quote Link to comment Share on other sites More sharing options...
Biggles' Elder Brother - Moderator Posted November 18, 2010 Share Posted November 18, 2010 You have big feathers in your part of the world Lee? BEB Quote Link to comment Share on other sites More sharing options...
Lee Smalley Posted November 18, 2010 Share Posted November 18, 2010 you should see the birds sadly it was a Mid air been flying since i was 15 and my first ever mid air !!!! Quote Link to comment Share on other sites More sharing options...
Stephen Grigg Posted November 18, 2010 Share Posted November 18, 2010 Who came off best Lee,fortunately Ive had 2 middairs and landed both my models,the 2nd My expert was flying.We" d had trouble with an engine and just as he said,weve sorted it the other plane took the lower wing off,the ailerons were on the top wing. Quote Link to comment Share on other sites More sharing options...
Ross Clarkson Posted November 18, 2010 Author Share Posted November 18, 2010 Nooooooooooooooooo, why would you even do that to me Lee!!!!!!!!!!!!!!! Ha Ha, thanks. Quote Link to comment Share on other sites More sharing options...
Lee Smalley Posted November 18, 2010 Share Posted November 18, 2010 dont worry Ross its not a glimpse at the future as for who came of best well that was definitely a score draw, i almost got away with it but eventually the wing gave way and down i came but this is a mark of how great i rated the aircraft, i bought another straight away .........and i never do that for some reason i really don't like to do that Quote Link to comment Share on other sites More sharing options...
Ross Clarkson Posted November 18, 2010 Author Share Posted November 18, 2010 I hope not Lee!!!!!!!!!!!!! Well, as promised. Tail wheel fitted today. Holes drilled after trial fit of spring mechanism. Spring mechanism epoxied and screwed in place. Tail wheel strut holes marked and drilled. Tail wheel assembly fitted (Epoxied and screwed) and springs attached. .....and then for the first time ever, she is on all three wheels!!!!! Electrics, servo arm connections and fuel tank next!!!!! Cheers, Ross. Quote Link to comment Share on other sites More sharing options...
Stephen Grigg Posted November 18, 2010 Share Posted November 18, 2010 That shouldnt take long now Ross. Quote Link to comment Share on other sites More sharing options...
Lee Smalley Posted November 19, 2010 Share Posted November 19, 2010 just a quickie Ross put some threadlock on the nut that holds the tailwheel to the bracket (but still allows it to spin, mine came loose and i lost it, good job i kept the old one ! now held on with nyloc nut and threadlock Quote Link to comment Share on other sites More sharing options...
Ross Clarkson Posted November 19, 2010 Author Share Posted November 19, 2010 Already done Lee, as i was spinning it i also noticed the small nuts were coming loose so thread lock applied to them too.Cheers, Edited By Ross Clarkson on 19/11/2010 15:40:43 Quote Link to comment Share on other sites More sharing options...
Ross Clarkson Posted November 29, 2010 Author Share Posted November 29, 2010 An update for you: Control rods (Elevator) and pull-pull system completed with the help of a few brilliant guys.Mainly Timbo for explaining how to mix the 2 elevator servos and the pull-pull system thread.Thanks all. Elevator control rods set-up. Rx installed. Foam glued to servo deck, Rx velcroed onto foam and secured with cable ties. Other bit of Rx velcroed to sidewall 90deg from Rx. Rudder servo and pull-pull system installed.This was a new experience for me (see Pull-Pull system thread) but i like it a lot and i feel confident it is a very secure system. All electronics completed, installed and set-up, apart from throttle linkage for obvious reasons.Battery not secured as of yet until i work out correct Cofg.Leads all tidied up and secured neatly. Just the front end to complete after Xmas now, oh and the Aileron control rods. Cheers, Edited By Ross Clarkson on 29/11/2010 20:14:04 Quote Link to comment Share on other sites More sharing options...
Ross Clarkson Posted November 29, 2010 Author Share Posted November 29, 2010 Again, couldnt resist a little test fit!!!!!!So big and solid!!Cant wait until Xmas now to get my engine!! Im like a big kid. Thanks. Quote Link to comment Share on other sites More sharing options...
Stephen Grigg Posted November 29, 2010 Share Posted November 29, 2010 Well done Ross,roll on Xmas a itll look good with the OS40 LA I sold off E Bay Quote Link to comment Share on other sites More sharing options...
Lee Smalley Posted November 30, 2010 Share Posted November 30, 2010 it is an exceptionally pretty thing and for the price !!!! its just fantastic ps had a deadstick last week at the bottom of a bunt (must stop doing bunts with no fuel) and i thought i had fluffed it up and went too far down on the base leg i really thought i was going to end up in the scrapyard at the end of the field, but my baby kept coming and coming thankfully there was no wind and she made the strip just i was staggered how slow she really will fly, not that i would risk that again like but she really does have impeccable manners, i was a lucky boy! Quote Link to comment Share on other sites More sharing options...
Lee Smalley Posted November 30, 2010 Share Posted November 30, 2010 Quote Link to comment Share on other sites More sharing options...
Ross Clarkson Posted November 30, 2010 Author Share Posted November 30, 2010 Wow, good stuff Lee.I think i will definitely if i lose her!!!!!!! Quote Link to comment Share on other sites More sharing options...
Ross Clarkson Posted November 30, 2010 Author Share Posted November 30, 2010 Also Lee, whilst you are here:My Thunder Tigre F-130S recommends a 14x10 prop.Any ideas what spinner i should go for to fit it with no cutting?I am thinking 2 3/4" or 3". Quote Link to comment Share on other sites More sharing options...
Stephen Grigg Posted November 30, 2010 Share Posted November 30, 2010 The one that came with the kit RossLee your just to modest,it was obviously your skill that saved the model Quote Link to comment Share on other sites More sharing options...
Lee Smalley Posted November 30, 2010 Share Posted November 30, 2010 that was the same skill that put me in the rubbish position in the first place eh !!!! Quote Link to comment Share on other sites More sharing options...
Lee Smalley Posted November 30, 2010 Share Posted November 30, 2010 can't remember what spinner size i used i will have a measure ASP props have a funny twist on them at the root and you might have problems with a 10 pitch prop (cutting wise) the only poor thing in the entire kit is the Spinner put it where it deserves to go ...the BIN Quote Link to comment Share on other sites More sharing options...
Ross Clarkson Posted December 9, 2010 Author Share Posted December 9, 2010 Just a few shots of the decals applied.Controls have been set-up basically at the minute, all is working but some fine tuning will be needed.Literally, just the fuel tank, engine installation and cowl to complete now! Cheers, Quote Link to comment Share on other sites More sharing options...
